Fuel pump painted ?? #1620679
05/16/14 04:42 PM
05/16/14 04:42 PM
Maryland USA
beatgoeson Offline OP
Maryland USA
Was the Fuel pump installed prior to painting a typical 440? I seem to recall back in the day see original Fuel pump with a lot of engine paint on them. Most restored cars I see now are unpainted. any thoughts?
Re: Fuel pump painted ?? [Re: beatgoeson] #1620680
05/16/14 05:16 PM
05/16/14 05:16 PM
california
Mr D21 Offline
Mr D21  Offline
california
here you go...
Re: Fuel pump painted ?? [Re: Mr D21] #1620681
05/16/14 09:57 PM
05/16/14 09:57 PM
Yes, 440's were bolted to the engine prior to it being painted. If you have a vapor separator on your car, the bolt that holds the vapor separator to the fuel pump should not have engine colored paint on it. The bolt would have been replaced when they installed the vapor separator.
Re: Fuel pump painted ?? [Re: ] #1620682
05/16/14 10:16 PM
05/16/14 10:16 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Big blocks,383/440, yes, pump was painted on the engine. 318/340/360 and Hemi, no, they were added after paint.
Re: Fuel pump painted ?? [Re: ] #1620683
05/16/14 11:04 PM
05/16/14 11:04 PM
california
Mr D21 Offline
Mr D21  Offline
california
hmmm - are you sure about that. I'm pretty sure my original 70 440 had orange paint on both bolts. Besides, why would the factory throw away a bolt that doesn't show anyway ??
Re: Fuel pump painted ?? [Re: Mr D21] #1620684
05/17/14 12:49 AM
05/17/14 12:49 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
The example you posted has it not painted
Re: Fuel pump painted ?? [Re: Morty426] #1620685
05/17/14 01:13 AM
05/17/14 01:13 AM
Maryland USA
Maryland USA
That looks like the Frank Badalson motor on display at Carlisle. I can't tell if the VS bolt has paint on it or not.
Re: Fuel pump painted ?? [Re: beatgoeson] #1620686
05/17/14 03:18 AM
05/17/14 03:18 AM
I seem to remember an article in Mopar Collectors Guide (maybe I'm wrong) but it was an article that Frank Badalson did and it had a picture of the bolt with the vapor separator.
Re: Fuel pump painted ?? [Re: ] #1620687
05/17/14 10:09 AM
05/17/14 10:09 AM
Land of 10,000 Lakes
44D6PAKCUDA Offline
44D6PAKCUDA  Offline
That is my motor Frank did for my Cuda and if I remember right,the one bolt is unpainted.I can double check this weekend as it may be a balmy 51 degrees and I can get it out for the first time this year
Re: Fuel pump painted ?? [Re: 44D6PAKCUDA] #1620688
05/17/14 08:04 PM
05/17/14 08:04 PM
Upper Michigan
sixpacchallenger Offline
Upper Michigan
Just picked up a a12 road runner original owner car . Replaced the fuel separator and for sure both bolts are painted. The engine was never painted after it left the factory. They would have never replaced the bolt,because it had paint on it.
Re: Fuel pump painted ?? [Re: sixpacchallenger] #1620689
05/17/14 10:54 PM
05/17/14 10:54 PM
By that thinking for cars with power steering it would have had an engine paint colored bolt at the one pivot but I am pretty sure they had a zinc phosphate plated bolt.
