Cam Plug on a 440
#1619936
05/13/14 10:40 PM
05/13/14 10:40 PM
Posts: 198 Chester, VA
tobnHisglory
Chester, VA
Hey everyone. I just had cam bearings put in my 440 block and I'm going to assemble soon. The machine shop didn't put a plug in the back of the block behind the cam. Does anyone know a part number I can get locally so I don't have to order a whole kit? Should this be brass instead of steel to act as a bearing material with the force of the cam spinning against it? Thanks!
-Reggie tobnHisglory2000@aol.com Former Mopars: 73 Charger - 440/727, 68 D200 Camper Special 383/727, 67 Satellite, 71 Superbee, 73 RoadRunner,2009 Ram Quad Cab Hemi 4x4 Current Mopars: 2005 Ram Quad Cab Hemi 4x4, 73 Cuda FE5 318 manual
Re: Cam Plug on a 440
[Re: Mr.Yuck]
#1619938
05/13/14 10:55 PM
05/13/14 10:55 PM
tobnHisglory
Chester, VA
Thanks Jeff, will do. I tried Autozone and Advnace Auto and neither had it. Nothing quite that big. I will try Napa tomorrow but was hoping to have a part number so they could check the warehouse.
[Re: tobnHisglory]
#1619939
05/13/14 11:00 PM
05/13/14 11:00 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
yeah sad to say if it's not in the computer nobody knows what you are talking about anymore. NAPA should be a better option. You can also try rockauto online. "DORMAN Part # 555065 {#2402905, 567944} Nominal Dia.: 2-9/64"; Metric Dia.; 54.41mm; Steel; Height: 0.432"; Open End Dia.: 2.150" 2.1406 In. Steel Cup; 1-Req Choose: ($0.74) {10}+(Only 1 Remaining) ($0.77) {1}+ * * Stocked in outlying warehouse--shipping delayed up to 2 business days + Sold in packs of {x}; Price reflects cost of each individual item, not the pack $0.74 See Options at Left DORMAN Part # 570016 Nominal Size: 2-1/8"; Metric Size: 53mm; Metric Range: 53mm - 57mm 2-1/8" - 2-1/4" (53mm - 57mm) Quick Seal Rubber (1-Req) Choose: ($1.89) {5}+(Only 5 Remaining) ($2.33) {1}+ * * Stocked in outlying warehouse--shipping delayed up to 1 business day + Sold in packs of {x}; Price reflects cost of each individual item, not the pack"
