R3 9.00 Deck Cooling #1619888
05/13/14 08:49 PM
05/13/14 08:49 PM
CEDAR RAPIDS
Plymouth340 Offline OP
CEDAR RAPIDS
Just wondering how these blocks cool with the water pump holes in the front of the block half blocked off. Because I just purchased a complete motor and wanted to know in advance,,,thanks
Re: R3 9.00 Deck Cooling [Re: Plymouth340] #1619889
05/13/14 08:56 PM
05/13/14 08:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Its no problem at all... plenty of water passes through
that hole
Re: R3 9.00 Deck Cooling [Re: MR_P_BODY] #1619890
05/13/14 10:10 PM
05/13/14 10:10 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
There are a lot of " tricks " you can do to these to facilitate cooling.
Most are laid out in the How to build Big Inch Small Block MoPar's book.
I tapped and plugged the holes going up to the heads from the ends of the deck and drilled them out to 1/8" to force more coolant up through the center of the head.
I am using a remote pump and the coolant enters the block through the center core plugs too.
I didn't mess with trying to drill between the bores , but if I was going to burn gas , I might have considered it.
This is for a dual purpose motor though......if you are not going to drive on the street or in circles , I think a lot of it is over kill.
Re: R3 9.00 Deck Cooling [Re: tubtar] #1619891
05/13/14 10:30 PM
05/13/14 10:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
When I first built my R3 W-9 it was on gas and it never
had any heat issues(it was a drag race only car)...
what will the engine be used for... I did drill and
tap the top centers on each side of the block but never
needed any more cooling and when I switched over to
E-85 I had to run it in the lanes to keep the temp up
Re: R3 9.00 Deck Cooling [Re: MR_P_BODY] #1619892
05/13/14 11:01 PM
05/13/14 11:01 PM
CEDAR RAPIDS
CEDAR RAPIDS
this is drag race only on gas W7 heads
Re: R3 9.00 Deck Cooling [Re: Plymouth340] #1619893
05/13/14 11:11 PM
05/13/14 11:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You wont have any problems... just put a radiator
in the car
Re: R3 9.00 Deck Cooling [Re: MR_P_BODY] #1619894
05/13/14 11:41 PM
05/13/14 11:41 PM
CEDAR RAPIDS
CEDAR RAPIDS
in the car
thanks already got a good one in there
Re: R3 9.00 Deck Cooling [Re: Plymouth340] #1619895
05/14/14 02:00 AM
05/14/14 02:00 AM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
I drive a 900hp W8 headed 9.00 deck R3 on the street with zero cooling issues.
I have traveled over 30 miles on a summer evening, with a combination of highway and city, including a few illegal displays of acceleration and the temp never topped 180*.
Re: R3 9.00 Deck Cooling [Re: jim sciortino] #1619896
05/15/14 01:38 AM
05/15/14 01:38 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
To paraphrase Colonel Kurtz , " that's my dream.......that's my nightmare."
I won't be near 900 h.p. , but if I can scare the women and children , I'll be perfectly happy.
Re: R3 9.00 Deck Cooling [Re: Plymouth340] #1619897
05/15/14 01:40 AM
05/15/14 01:40 AM
go to www.moparchat.com then scroll down to and click on "circle track chat" then read thru Sanborns' cooling mods that are in a sticky at the top of the page. Your Q's will be answered
Re: R3 9.00 Deck Cooling [Re: RapidRobert] #1619898
05/15/14 02:34 AM
05/15/14 02:34 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
That has always been a wealth of info
Re: R3 9.00 Deck Cooling [Re: tubtar] #1619899
05/15/14 04:07 AM
05/15/14 04:07 AM
Trumbull,CT.
Trumbull,CT.
Just don't scare the police.
Re: R3 9.00 Deck Cooling [Re: jim sciortino] #1619900
05/15/14 02:27 PM
05/15/14 02:27 PM
Finland
mafo Offline
mafo  Offline
Finland
You two could scare women and children just by going outside
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
Re: R3 9.00 Deck Cooling [Re: mafo] #1619901
05/15/14 05:26 PM
05/15/14 05:26 PM
Trumbull,CT.
Trumbull,CT.
Mafo knows too much!!!
Re: R3 9.00 Deck Cooling [Re: jim sciortino] #1619902
05/15/14 06:22 PM
05/15/14 06:22 PM
Finland
mafo Offline
mafo  Offline
Finland
luckily, I live far away from you bullies
Re: R3 9.00 Deck Cooling [Re: mafo] #1619903
05/15/14 07:16 PM
05/15/14 07:16 PM
Trumbull,CT.
Trumbull,CT.
I wish you lived closer, we could terrorize unsuspecting women and children together.
Re: R3 9.00 Deck Cooling [Re: jim sciortino] #1619904
05/17/14 03:20 AM
05/17/14 03:20 AM
Orlando Fl
Dos Snails Offline
Dos Snails  Offline
Orlando Fl
I you lived closer, we could terrorize unsuspecting women and children together.
Where is the like button when you need it!
Re: R3 9.00 Deck Cooling [Re: Dos Snails] #1619905
05/17/14 11:37 AM
05/17/14 11:37 AM
Central,Ohio
FASTFISH420 Offline
FASTFISH420  Offline
Central,Ohio
Thats a rare WC block..its a good one! I run one myself
1969 Barracuda 8 second all/motor small block 2014 Shelby GT500 Mustang Uratchko Racing Engines www.URE-RACING.com
