91 d150 engine question? #1619728
05/13/14 11:15 AM
05/13/14 11:15 AM
cmansell Offline OP
cmansell  Offline OP
I saved a 91 shortbed from going to scrapyard, everything but an engine. transmission and underhood complete. What year engine can I use with this harness and computer. I think it was a 318 and froze this winter so it was running not long ago. Thanks.
Re: 91 d150 engine question? [Re: cmansell] #1619729
05/13/14 12:00 PM
05/13/14 12:00 PM
scratchnfotraction Offline
for plug and play another 91 d-150 318 from the JY
any of the tbi roller cam 318 enegines should work.
I pick up 88-91 TBI-318 roller cam engines to trans plant into older trucks.
right now I have a 91 318 with a hughes whiplash roller cam/93-NV4500 5 speed in my 85 stepside. awsome little 318. but no worky with a 91-TBI/PCM
Re: 91 d150 engine question? [Re: scratchnfotraction] #1619730
05/13/14 12:08 PM
05/13/14 12:08 PM
I did just pick up a 800$ 88-d150 with a older engine swped into it..the PCM/wireing was removed and they splide in a VR along with a ECU/elect dist.
so that is an option if you want/have too go that way.
it is not that hard to splice/by-pass into the intank fuel pump to run a regulator with a return line at the carb.
then splice the VR plug/VR into the harness and mount it on firewall. then wire in the mopar eletc ECU/dist.
do you have all of the brackets/alt/ps pump/pullys to go on it?
Re: 91 d150 engine question? [Re: scratchnfotraction] #1619731
05/13/14 12:51 PM
05/13/14 12:51 PM
cmansell Offline OP
cmansell  Offline OP
Most all the parts were left connected or in the bed, but I really won't find out what's missing until another engine goes in.
Re: 91 d150 engine question? [Re: cmansell] #1619732
05/13/14 12:54 PM
05/13/14 12:54 PM
cmansell Offline OP
cmansell  Offline OP
Does the transmission need to keep the computer?
Re: 91 d150 engine question? [Re: cmansell] #1619733
05/13/14 03:37 PM
05/13/14 03:37 PM
depends on the trans..I am not sure.
Re: 91 d150 engine question? [Re: cmansell] #1619734
05/13/14 04:41 PM
05/13/14 04:41 PM
Crockett ,TX
9
98RAM1500 Offline
98RAM1500  Offline
Crockett ,TX
If its a auto with OD then yes, but if its a 3spd auto then no.
Re: 91 d150 engine question? [Re: 98RAM1500] #1619735
05/13/14 07:38 PM
05/13/14 07:38 PM
Thayer, MO
bohmer2 Offline
bohmer2  Offline
Thayer, MO
There are also work arounds that will allow you to manually switch the OD on. I believe in the tech section off the moparts main page there is a couple of old examples of how to wire an OD up without the electronics (or at least without the full harness swap).
Re: 91 d150 engine question? [Re: bohmer2] #1619736
05/13/14 07:45 PM
05/13/14 07:45 PM
cmansell Offline OP
cmansell  Offline OP
I thought I noticed a small bundle of 3 or 4 wires pulling off the harness and dropping off at the trans tunnel but I've not been under there to see where they go.
Re: 91 d150 engine question? [Re: cmansell] #1619737
05/13/14 10:04 PM
05/13/14 10:04 PM
Hawley, Texas
shinnery Offline
super street
shinnery  Offline
super street
Hawley, Texas
If it is towards the back driver's side of the tranny it may be neutral start/back-up lites wiring.
Bryce
Every electronic device is manufactured with smoke stored deep inside... only a true genius can find a way to set it free. The most terrifying words in the English language are: "I'm from the government and I am here to help!"
Re: 91 d150 engine question? [Re: shinnery] #1619738
05/14/14 01:53 PM
05/14/14 01:53 PM
cmansell Offline OP
cmansell  Offline OP
Any 91 from Dakota or van or ramcharger should be ok with this harness?
