Plastic Clip ?? #1619644
05/13/14 01:45 AM
05/13/14 01:45 AM
Nelsonville , Ohio
Duster3105 Offline OP
Nelsonville , Ohio
I am putting together a pretty nice little 85 short wheel base pickup, 2 tone, 440 8 3/4, changed front rotors to get 4 1/2 bp, etc... I am now looking for the plastic molding clips, 1 3/16 X 3 1/2, I have all the originals But, spring ears are broken on some or most. Is there any place special to get these clips? I found a used one on ebay for $7.99, are they that hard to get? If anyone has an idea I would appreciate it,
Thanks / Rick
Re: Plastic Clip ?? [Re: Duster3105] #1619645
05/13/14 04:14 AM
05/13/14 04:14 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Did you do a search here on the board ? They are out there and going rate is around $10.00 each.
I am truckless..
Re: Plastic Clip ?? [Re: 340SHORTY] #1619646
05/13/14 09:42 PM
05/13/14 09:42 PM
Nelsonville , Ohio
Nelsonville , Ohio
Wow! $10.00 ea. I may try and reuse these, I think there is something like 30-32 of them needed. I'll check around some more too, Thanks for the response
Rick...
Re: Plastic Clip ?? [Re: Duster3105] #1619647
05/13/14 10:34 PM
05/13/14 10:34 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
You might check with Restoration Specialties.
Re: Plastic Clip ?? [Re: 70Duster440] #1619648
05/13/14 10:54 PM
05/13/14 10:54 PM
Waynesboro PA 17268
RODHALL Offline
RODHALL  Offline
Waynesboro PA 17268
this has been answered 3-4 times....
Call around, our local body supply shop can get these clips for $2.50 a clip.. check PPG/DuPont paint supplers they may also be able to get them
