Re: 71 B Body shuts off after about 2 miles(fresh build)
[Re: RapidRobert]
#1619145
05/14/14 06:29 PM
05/14/14 06:29 PM
Posts: 4,664 Newfoundland
mopar_man
Newfoundland
it has spark and fuel and compression as it runs strong for the first few miles , then dies .
It's loosing one of those (other than compression). Right when it dies, it has a good squirt and spark when turned over with the key? I know that sounds simple & you've already checked that but keep us in touch. I love the toughies
Robert , so do I, but after 50 years messin with mopars and doing just about everything conceivable with what I could afford, I have no answer for my buddies problem . He doesn't live close to me and everything I told him to do over the phone , he had already done other than a few simple tricks. I even asked him to do a compression check on the side of the road. The funny thing is that after about 5 min it will start right up as if nothing was wrong. he's not stupid either , he's over 60 and a mechanic by trade . Unless he tears the engine apart to find a ghost , I just don't know what to tell him and feel embarrassed that I can't get something so simple to run.
[Re: mopar_man]
#1619146
05/14/14 06:33 PM
05/14/14 06:33 PM
Posts: 1,565 tennessee
pushbutton
tennessee
A friend of mine got the same problem with his 71 cuda 6 pak . runs for about 2-4 miles then shuts off and can't start it . he has changed everything that he and I can think of . he has mechanical pump and installed new one . ran a gallon can under the hood to eliminate all the gas line and tank . same result . changed the whole electrical system including the dizzy , coil , resistor and tried it on his other rig , everything checks out ok . But his cuda won't run more than a couple of miles . he and I are stumped . it has spark and fuel and compression as it runs strong for the first few miles , then dies . also jumped wiring system direct from battery , still shuts off . Guess I can't offer you anything that haven't already been said but if you get it right , please let us know .
How hot is the coil when it quits running?
[Re: pushbutton]
#1619147
05/14/14 06:45 PM
05/14/14 06:45 PM
Posts: 1,220 toronto canada
69chargeryeehaa
toronto canada
I had this EXACT same problem....TWICE!!! Both times it was ignition related. 1st time it was the coil. 2nd time it was the ecu (stock orange). The ecu problem started out at every 30mins just shut off like you turned the key off, instant off, no stumble nothing, then wait 5-10mins, and started right up. as it got worse it was every 5 mins like clockwork!!, i tired everything i could think of and thought it was fuel related, changed the ecu...problem gone!! These 2 problems were years apart!! I also vaguely remember having a problem with the pick-up with the coil problem.....
[Re: pushbutton]
#1619149
05/14/14 07:42 PM
05/14/14 07:42 PM
mopar_man
Newfoundland
been there done that several times , he mounted a coil on the inner fender to eliminate that potential problem , thanks for the help though .
[Re: mopar_man]
#1619150
05/14/14 07:52 PM
05/14/14 07:52 PM
pushbutton
tennessee
Double check how the coil is wired.
