MLS Cometic Weeping #1618837
05/11/14 05:09 PM
05/11/14 05:09 PM
N.E. Ohio
6bblFLASH Offline OP
N.E. Ohio
Have one head weeping,not too bad mineral stains on block and sizzles when you park it.
I`m not going to tear it apart just for this reason,only uses a cup of water every 2/3 uses.
Is a block sealer even worth trying?
What would you use?
K&W Copper seal has worked for me on porosity/crack issues before.
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: MLS Cometic Weeping [Re: 6bblFLASH] #1618838
05/11/14 08:31 PM
05/11/14 08:31 PM
Do not use K&W block sealer for that, try Alumana(SP?) Seal instead Sounds like you have a non smooth,(courser than 50 RA) rough, head or block surface
