Re: School me on slick shift & crash boxes
[Re: Big Squeeze]
#1618711
05/11/14 01:07 PM
05/11/14 01:07 PM
Posts: 617 PA
bwhackd34
PA
[Re: nz383man]
#1618715
05/11/14 02:39 PM
05/11/14 02:39 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
Like Bob says the factory type "slick shift" boxes do need regular maintenance if you put many hard passes on them. I would get a face-plate input and third gear with the correct slider and have Liberty's modify the side cover too. I have driven just about every different kind of modified 4-speed Chrysler box and the face-plate is the best way to go Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#1618716
05/11/14 04:36 PM
05/11/14 04:36 PM
Posts: 2,128 sweden
sshemi
sweden
Been there done that. I would never ever do a slick shift again after trying faceplate. Slick shift wares out the dog teeths so fast its not even funny. And thats after you have spent alot of hours grinding every other teeth off. Faceplate is not cheap but WELL worth it in my opinion. What is the liberty cover mod?
[Re: sixpacksteve]
#1618720
05/11/14 11:18 PM
05/11/14 11:18 PM
Posts: 209 Mesa, Arizona
6pak2go
Mesa, Arizona
I had Liberty Face-plate 2nd, 3rd, and 4th in my 18 spline A-Body box. They cut the synchro rings off each gear and weld a face plate to each. It was $80.00 per gear plus the cost of the new dog ring sliders. The pic shows the gears and the new sliders vs the old ones. Also, the side cover mod, which they bore out the holes and press in seals. The lever rods are larger diameter. Call Liberty, good folks to deal with.
Robert R Mesa, AZ 70 Challenger R/T 440-6 4-Sp Cruiser 67 Barracuda FB 540 4-Sp Strip/Street and Drag Week
