Re: Can a coil break up under a load?
[Re: Belvedere1]
#1618573
07/14/14 09:56 PM
07/14/14 09:56 PM
Posts: 941 Texas, USA
ChrgrCuda
Texas, USA
Just found this thread after my search under "bad coil". My 69 440 Charger suddenly took a crap when my wife and I went riding one day. It would barely start and when it did it misfired and you dam near had to floor it to keep it running. Firecore Distributor and coil, MSD 6AL-2. Thought for sure it was the MSD, sent it off to El Paso Texas to have it looked at. Got it back, same dam thing. When I reinstalled the distributor and MSD after having it checked out, it would only start when cold. It wouldn't idle below 38 degrees initial. I checked the MSD and it lit my ass up and dam near blew my fillings out. Then I check spark to the FireCore coil after getting it to run for a little while and had no spark. I then installed my Blaster 2 coil off my Cuda to the Charger and it fires right up, put initial timing down to 18 degrees initial and it runs like it did before. Never have I seen a coil cause this kind of problem, but I'm no expert. Firecore coil only 2.5 years old.
68 Cuda Notchback [Email]10.86@120[/Email]
69 Charger R/T 440/505
2009 Challenger SRT8
