Re: Heavy pedal on Holley 770 street avenger
[Re: Fern]
#1617871
05/09/14 01:39 AM
05/09/14 01:39 AM
RapidRobert
Since the pedal/cable is free it would have to be the carb: As said throttle cable mounted to the horizontle pin too close to throttle shaft centerline. I'm assuming the angle of the cable/connections looks OK
[Re: 451Mopar]
#1617873
05/10/14 03:17 AM
05/10/14 03:17 AM
Posts: 233 vashon island washington
hunterstroble
Are the throttle blades witting the intake or gasket, loosen the mounting bolts and see if it gets better, then you know.
1969 Dodge dart 500 stroker
1973 Dodge Challenger 440
