Brown zinc parts..resto
#1617789
05/08/14 06:10 PM
05/08/14 06:10 PM
Posts: 1,553 Sweden
71redcuda
Sweden
Hello,
Im looking for a someone who can do the correct factory plating (brown zinc) on a hood latch now when Jules is no longer with us..
Looking for a high quality resto if avalible.
THANKS Nicklas
Re: Brown zinc parts..resto
[Re: ScottSmith_Harms]
#1617794
05/09/14 03:37 AM
05/09/14 03:37 AM
Posts: 1,553 Sweden
71redcuda
Sweden
Yes, he's a very nice guy.
Will try him, appreciate the help with this.
[Re: 71redcuda]
#1617796
05/09/14 07:43 AM
05/09/14 07:43 AM
Posts: 1,386 Philadelphia PA
Pynzo
Drugs are bad
Drugs are bad
Philadelphia PA
That finish is called Parkerized and you can do it yourself very cheaply. I started doing my own 20 years ago restoring Harley parts. Manganese and Zinc phospating developed by the Parker Chemical Co. way back in the day. All you have to do is soak the cleaned steel(glass beaded or wire brushed and degreased) in the heated solution for a bit and oil it after you pull it out. http://www.shootersolutions.com
[Re: Pynzo]
#1617797
05/09/14 12:29 PM
05/09/14 12:29 PM
Posts: 2,304 WI
RestoRick
WI
As stated by the original poster, these are done with black zinc. It's clear (silver) zinc followed by a chromate bath, brownish black in this case. Often mistaken for parkerizing or phosphating, but it's most definitely not.
[Re: 1970A13]
#1617800
05/10/14 02:09 AM
05/10/14 02:09 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
See: http://www.iccahome.org/and click on black zinc in left margin. AFAIK, hood safety catches should be black zinc, not phosphated. Black zinc is not so black in many cases.
[Re: kentj340]
#1617801
05/10/14 02:42 AM
05/10/14 02:42 AM
kentj340
Cut and Shoot, TX
How to tell the difference between black zinc (or any zinc plating) and phosphate:
Dip a toothpick in a fairly strong acid and deposit a small drop on an unexposed part of the test piece. I use phosphoric acid (Rust Cure) for this, because I always have some, and I know how it behaves on zinc. If tell tale bubbles soon appear, the coating is likely zinc, because zinc is highly reactive with acid. Apply water to stop the reaction, and no harm done.
Mostly you never want to put zinc plated parts in acid, because the zinc will be totally consumed in a fraction of an hour or so, even with a weak acid like vinegar. Zinc plating is usually in the range of only 0.0001" to 0.0002" thick. When doing zinc plating or chromating, HCl is used for a dip cleaner, but the exposure is in seconds.
[Re: kentj340]
#1617802
05/10/14 07:55 AM
05/10/14 07:55 AM
Tropicalcats
Stephan.Fournier@videotron.ca Stephan has my hood and trunk laches and in talking with him I have every reason to expect a quality product. Aside from the correct finish he will disassemble and reassemble with the proper rivets. He has big shoes to step into but in talking with him and seeing some pics I think he can do it.
[Re: Tropicalcats]
#1617803
05/10/14 11:13 AM
05/10/14 11:13 AM
Posts: 3,267 Connecticut
1972CudaV21
Connecticut
Does RestoRick use the correct rivets?
[Re: 1972CudaV21]
#1617804
05/10/14 05:22 PM
05/10/14 05:22 PM
Tropicalcats
Not sure. I know that Stephan worked with Jules and for me that says it all.
[Re: 71redcuda]
#1617805
05/10/14 08:27 PM
05/10/14 08:27 PM
Posts: 602 Portage Wisconsin
Lou_Steger
Portage Wisconsin
Hello,
THANKS Nicklas
What happened to Jules?
[Re: Lou_Steger]
#1617806
05/10/14 09:41 PM
05/10/14 09:41 PM
Tropicalcats
Hello,
THANKS Nicklas
Jules passed away from cancer. A great loss.
[Re: 1972CudaV21]
#1617808
05/11/14 01:17 AM
05/11/14 01:17 AM
Posts: 2,304 WI
RestoRick
WI
I don't do the hood & trunk latches...
