Mopar Performance Cast Covers Leak
#1617270
05/06/14 10:50 PM
05/06/14 10:50 PM
Posts: 1,212 Canton, Ohio
Crazy68Dart
Canton, Ohio
I have been doing so searching, it appears that this is a very common problem. Back driver side on mine is leaking. I was using rubber coated cork. From the searching it appears that Mr Gasket Ultras might be the ticket? Anything better these days? I am going to make sure they are not hitting on anything (383 with 906 heads and RPM intake). But I don't think they are. They rock on the head without a gasket. Thanks!
383, Hemi 4-Speed, AlterKtion, D60
Re: Mopar Performance Cast Covers Leak
[Re: Crazy68Dart]
#1617271
05/06/14 11:03 PM
05/06/14 11:03 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Iv had 1 SB set and 2 BB sets. Never had a single leak..
I am truckless..
[Re: ahy]
#1617275
05/07/14 12:48 AM
05/07/14 12:48 AM
Posts: 21,076 Niles , Ohio
therocks
Niles , Ohio
My kid put his on the 413 about 4 years ago.Used the Mr Gasket Ultras.No leaks.They are the only gaskets we run.Ive had covers off a few times and they still seal.We use there header gaskets also with great results.Rocky
Chrysler Firepower
[Re: DaytonaTurbo]
#1617278
05/07/14 09:18 AM
05/07/14 09:18 AM
Crazy68Dart
Canton, Ohio
I have a set of Mr Gasket Ultras on the way (thanks Jegs!).
I am going to glue them to the cover, but not the head. Hopefully they are thick enough to seal without having to crank down on the valve cover too much and risk cracking it.
If I can't get them to seal I'll probably go back to a set of stamped steel covers that will better contour to the imperfections on the head mating surface.
[Re: 70sixpkrt]
#1617285
05/08/14 04:22 AM
05/08/14 04:22 AM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
Moroso rubber over steel ,no sealer and never a leak.Stamped covers, cast or fabbed.Stock cyl heads or aftermarket with a machined rail.Expensive as the best usually is.
Leave the gun.......take the Cannoli's....Mike
[Re: DaytonaTurbo]
#1617286
05/08/14 08:53 AM
05/08/14 08:53 AM
Posts: 951 Alliance, Ohio
Valiant_Showoff
Alliance, Ohio
I siliconed the gasket to the valve cover, but not to the head.
That's what I did too. No leaks and I had my covers on and off all the time due to adjusting the valve lash on mechanical cam.
[Re: Crazy68Dart]
#1617288
05/08/14 01:59 PM
05/08/14 01:59 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
How bad do they rock? If the flange is flat you can lap it on a flat surface using sandpaper to straighten it out a bit.
