Re: Chassis Dyno tune today. Results.
[Re: 70ucode]
#1617134
05/06/14 05:55 PM
05/06/14 05:55 PM
Posts: 5,162 CT
GTX MATT
CT
John, I can't read the column headings. Are we looking at horsepower or torque? I assume column 1 is HP and column 2 is torque? Air fuel in column 4? What did it make to the crank?
Where did you go? Danbury Chassis dyno?
[Re: 70ucode]
#1617135
05/06/14 07:42 PM
05/06/14 07:42 PM
Posts: 4,313 Prospect, PA
BSB67
Prospect, PA
Very nice! Cudabin has put one together something similar to yours. I think he was planning to take it to the track this year. I'm looking forward to those results and I think they will be really impressive as well. Do the 5300+ rpm power numbers look right to you? The one that I had was similar to yours (actually a smaller cam and a little less LSA) peaked about where yours does, but carried respectable numbers past 5600 rpm. In fact shifting at 5600 gave the lowest et and highest mph. Maybe lifters or fuel pressure Nice numbers none the less
[Re: BSB67]
#1617137
05/06/14 09:28 PM
05/06/14 09:28 PM
Posts: 3,916 usa
lewtot184
usa
Very nice!
the power band pretty much mimics what my r/t did on the chassis dyno. my numbers were lower, being an automatic, but power curves are very close.
[Re: 70ucode]
#1617141
05/07/14 11:55 AM
05/07/14 11:55 AM
Posts: 5,162 CT
GTX MATT
CT
Rob, can you educate me on what that means. By fat, do you mean rich? By more to it, do you mean we can find more power? If so, is there a sacrifice in driveability?
Thnaks.
Yeah fat is rich - and you are pretty rich from about 4000 rpm up. Those are in the range of most good running turbo cars. You'd make better power closer to 12.5:1 - 13:1 through the rpm range. Its probably in the outboards. Did Jeff play with the carbs much?
