Date codes for the 1970 model year - complete list?
#1616813
05/06/14 01:37 AM
05/06/14 01:37 AM
Posts: 29,657 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Hey guys, I am working on another article for HH. I have access to a very original car that was built a bit early, in the month prior to the scheduled production date on its fender tag. Looking at the date codes on it so far has been fun & I have started a spreadsheet to track them.
Not all of the possibilities listed below have been checked on this car yet, but I have seen them on other 1970 model year cars. If you know of something not shown, please mention it so I can add it to the list and / or check it on this car.
I will edit the list as more possibilities are reported.
Thanks!
Barry
AC clutch field coil * A/C evaporator/drier * AC hose * Air Grabber switch Alternator Battery Bellhousing * Blower motor * Bumper jack mechanism Calipers * Caliper mounts * Carburetor Carpet tag – front Carpet tag - rear Clock Coil Console * Convertible boot cover Dash pad * Dimmer switch Differential ring gear Distributor Door jamb switches Door panels * Engine casting date Engine final assembly date Engine mounts * Exhaust manifolds Engine main bearings Engine rod bearings Fan belt * Fuel pump * Gauge cluster Harmonic balancer Headlight switch Heads Headlights Headlight door motors Heater box * Heater fan / AC switch * Hood hinges * Hood latch Horn Horn Relay * Horn switch Intake manifold K-frame Lower control arms Muffler(s) Mylar door sticker Oil sender * Outside mirror glass * Plug wires * Power steering belt * Power steering hose * Power steering pump final assembly day * Power window motors Radiator Radio Rear window defogger Rear window defogger switch Rear end gear housing casting date Rear valence Scheduled production date from fender tag Seat belts Seat frame - rear, bottom Seat frame - rear, top Seat frame(s) front Seat tracks front Seat upholstery Shocks * Space Saver spare inflator bottle Speaker(s) Starter Steering column * Steering pulley * Sure grip carrier Tachometer Temp sender * Thermostat housing * Tires Transmission casting date Transmission final assembly date Transmission mount * Transmission tail shaft Trunk mat * Torsion bars * U-joint straps Vinyl top Voltage regulator Washer motor Water pump * Water pump housing * Wheels Windows Wiper motor Wiper motor switch
Re: Date codes for the 1970 model year - complete list?
[Re: Alaskan_TA]
#1616821
05/06/14 02:47 AM
05/06/14 02:47 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
Hood safety catch Blower switch Switch, evaporator temperature control A/C hose A/C clutch field coil A/C evaporator/drier Reverse switch
[Re: Alaskan_TA]
#1616825
05/06/14 03:38 AM
05/06/14 03:38 AM
Posts: 17,521 Las Vegas, NV
6bblgt
Las Vegas, NV
steering box clock tach sure-grip carrier rod & main bearings muffler bearings door jamb switches battery window motor headlight motor "air grabber" switch space saver inflator bottle you missed Scott's "tires" & my "horn switch" (added while you worked?)
[Re: Alaskan_TA]
#1616831
05/08/14 12:01 AM
05/08/14 12:01 AM
Posts: 777 Washougal,Wa
Dodge
Washougal,Wa
Hi Guys, Have a question. Have a 71 Satellite Pilot Car with a bunch of 000000 on front fenders. What do they mean if anything and can they be found on cars built later in the year? Thanks Terry
Stand behind your word
