Denso 120amp alternator brackets for BB #1616631
05/05/14 06:17 PM
05/05/14 06:17 PM
1969proDart Offline OP
Called mancini today said they aren't getting any brackets for another month for big blocks. Anyone know of anyone who sells them or can make them? Thanks. Need it sooner then a month.
Re: Denso 120amp alternator brackets for BB [Re: 1969proDart] #1616632
05/05/14 08:07 PM
05/05/14 08:07 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
PM AndyF here on the board.
Re: Denso 120amp alternator brackets for BB [Re: GY3] #1616633
05/05/14 10:10 PM
05/05/14 10:10 PM
Tried , none in stock 8(( I really don't want to fabricate my own. Just want to buy one done.
Re: Denso 120amp alternator brackets for BB [Re: 1969proDart] #1616634
05/05/14 10:30 PM
05/05/14 10:30 PM
Canton, Ohio
Crazy68Dart Offline
Crazy68Dart  Offline
Canton, Ohio
There is a 120 amp version of that little alternator now? Mine is rated at ~60 I believe. Progress is beautiful.
383, Hemi 4-Speed, AlterKtion, D60
Re: Denso 120amp alternator brackets for BB [Re: Crazy68Dart] #1616635
05/05/14 10:45 PM
05/05/14 10:45 PM
Denso 210-0138 120amp. Came out of 88 dodge d150's no idle charge issues ever after installing.
Re: Denso 120amp alternator brackets for BB [Re: 1969proDart] #1616636
05/05/14 11:07 PM
05/05/14 11:07 PM
scratchnfotraction Offline
I used a mini denso external regulated from a 88 b150 on my 440 with the stock non a/c brackets.
I did flip mine over to move the BATT stud out away from the VC/head. I did not want to grind the stud down and the field wires just clear the VC lip.
I just needed to cut up some new tube spacers to get it spaced out for the 2 belts to line up and lengthen the swing arm adjuster.
Re: Denso 120amp alternator brackets for BB [Re: scratchnfotraction] #1616637
05/05/14 11:13 PM
05/05/14 11:13 PM
Yea I'm going to end up fabbing my own setup.
Re: Denso 120amp alternator brackets for BB [Re: 1969proDart] #1616638
05/05/14 11:19 PM
05/05/14 11:19 PM
the BB with non a/c brackets was rather ez.
the 88 sb with the giant alt-a/c bracket sure is ugly but it gets a nice jack bolt adjuster with the 120 amp denso.
great upgrade for the charging system
just not very performance looking.
might look at Bouchillon web site they have brackets for the BB truck swaps. they might work for you with a little fab work.
