Anyone have a picture of a windage tray for a milodon 31160 oil pan.... I had a brand new oil pan but the windage tray was missing so i just made one for it out of aluminum..Not sure i made it like milodon does cause the drain back is slow and the vacuum pump is sucking oil into the canister and didn't have those problems with the pan i was using before ....This is on a 4.500 stroke motor
