Hood scoop pressure too much on big end. SSAH Type #1616513
05/05/14 02:46 PM
05/05/14 02:46 PM
Richmond, Tx. (Houston)
GTSDave Offline OP
GTSDave  Offline OP
Looks like I may have issues with my hood scoop working too well. Last outing on the big end my hood was wanting to lift up at the rear in the center. I was up in the 135mph range with a head wind.
Car is a 68 Barracuda FB with SSAH type HEMI scoop molded into a fiberglass hood. No carb / hood seal plate, just blowing down into the engine compartment.
What have you done to relieve pressure on the top end with your hood scoop? What do you suggest? What has worked for you in the past?
-Dave
PLEASE Pray for our brothers and sisters in harms way.
If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
Re: Hood scoop pressure too much on big end. SSAH Type [Re: GTSDave] #1616514
05/05/14 03:05 PM
05/05/14 03:05 PM
Those cars(A bodys) are noterous for that regardless of the scoop type or size, it is the air pressure from the front end coming into the engine compartment trying to blow the hood off, not the air coming into the scoop Put a carb. plate on it to seal the air from the bottom of the engine compartment and see if that helps, I would block the air from coming in from the grill, it will come in from behind the bumper and up from the K member area also A good spoiler mounted in front of the radiator core support will help also My tube chassis 1970 Cuda has issues also but I have not installed a spoiler or carb sealer yet It trys to blow the hood off at 135+ MPH also on the throttle stop it is worst at 145 MPH off the throttle stop I need to block the grill off and install a spoiler also
Re: Hood scoop pressure too much on big end. SSAH Type [Re: Cab_Burge] #1616515
05/05/14 03:12 PM
05/05/14 03:12 PM
GTSDave Offline OP
GTSDave  Offline OP
I don't think the class rules (NSS) would allow me to add a spoiler. Was thinking of a belly pan instead of an engine diaper. Maybe I can kill two birds with one stone.
Pretty sure I cant block off the radiator area either.
-Dave
Re: Hood scoop pressure too much on big end. SSAH Type [Re: GTSDave] #1616516
05/05/14 03:39 PM
05/05/14 03:39 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Drill holes in the back of the scoop..............
Re: Hood scoop pressure too much on big end. SSAH Type [Re: Thumperdart] #1616517
05/05/14 04:24 PM
05/05/14 04:24 PM
Addison,IL
OUTLAWSSAA Online content
OUTLAWSSAA  Online Content
Addison,IL
Dave, there's only one way to fix that problem. I had the same thing happen. You have to put in 8 pins. Three on each side of the hood, and that will take care of it.
Re: Hood scoop pressure too much on big end. SSAH Type [Re: GTSDave] #1616518
05/05/14 06:52 PM
05/05/14 06:52 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Fastest I've gone was 116 and my hood does the same thing,although it now lifts against the hood pins.I have 3 pins across the back and 3 across the front.71 Demon with snorkel scoop.
Nautilus Racing-
Re: Hood scoop pressure too much on big end. SSAH Type [Re: Thumperdart] #1616519
05/05/14 07:14 PM
05/05/14 07:14 PM
Mo.
racerx Offline
racerx  Offline
Mo.
^^^This^^^ I'm thinking of trying with my 5"T/A hood.
Re: Hood scoop pressure too much on big end. SSAH Type [Re: racerx] #1616520
05/05/14 07:27 PM
05/05/14 07:27 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Plus it really helped w/my O2 #`s WAY more solid probably due to helping w/the turbulence..........
Re: Hood scoop pressure too much on big end. SSAH Type [Re: GTSDave] #1616521
05/05/14 08:07 PM
05/05/14 08:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Block of the front... dont let the air in
Re: Hood scoop pressure too much on big end. SSAH Type [Re: OUTLAWSSAA] #1616522
05/06/14 01:30 AM
05/06/14 01:30 AM
GTSDave Offline OP
GTSDave  Offline OP
Thanks Outlaw,
I am no where near as quick as you guys. I run a low deck wedge with a Jerico. Still launching fairly easy, but the thing is making great power so we are slowing it down until we get it tuned the way we want. We built it to run FX Classes. The MPH has me worried with the scoop the way it is because it is already trying to pull of the car on the big end and we don't have it turned up yet. It will only get worse.
Right now we have brackets glassed in and we are using the factory style hinges with no springs. Up front one dutz in the center with two pins in stock location.
I may end up drilling the holes in the back of it, and probably adding more pins. With the hinges pins wont work because of the angle it opens at, but it is worth looking into. I am not sure how it would work with airflow across the carbs if we drill the holes. I use a heavily modified STR intake with dual eddy 800's inline configuration.
Thumper do you have any pics of yours you willing to share? What are you running for cabs, and did the holes make that much difference in your O2 readings?
-Dave
Re: Hood scoop pressure too much on big end. SSAH Type [Re: GTSDave] #1616523
05/06/14 02:53 AM
05/06/14 02:53 AM
fresno ca
mikeysmopars Offline
fresno ca
Although i'm no authoraty. I made a base and sealed it except for the front edge about 3/4". mine has run 135 and i also have 6 pins, Three in front and back. I've never had a hood issue....Unless you count the time the pins we not in it.
Founder and CEO of the Central Valley Mopar Drag Pack
Re: Hood scoop pressure too much on big end. SSAH Type [Re: mikeysmopars] #1616524
05/06/14 02:54 AM
05/06/14 02:54 AM
fresno ca
fresno ca
Base
Re: Hood scoop pressure too much on big end. SSAH Type [Re: mikeysmopars] #1616525
05/06/14 02:55 AM
05/06/14 02:55 AM
fresno ca
fresno ca
Hood
Re: Hood scoop pressure too much on big end. SSAH Type [Re: mikeysmopars] #1616526
05/06/14 08:35 AM
05/06/14 08:35 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I've run nearly 148 with this one, 4 pins. It does move around some.
Doug
Re: Hood scoop pressure too much on big end. SSAH Type [Re: dvw] #1616527
05/06/14 10:52 AM
05/06/14 10:52 AM
Windsor ,Ca.
K
Keith Richards Offline
K
Windsor ,Ca.
My '68 RR with a glass 6 pack hood raised up 1-1/2" every pass for years with no ill effects to the hood, some were I have a video of it, see if I can find it. My Challenger hood raises up about a inch as well it has a big pro stock type scoop and I drilled 4 - 1-1/4" holes in the back which had no effect so I just let it do it's thing as well as doesn't seem to hurt it either.
Re: Hood scoop pressure too much on big end. SSAH Type [Re: GTSDave] #1616528
05/06/14 12:41 PM
05/06/14 12:41 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Thanks Outlaw,
-Dave
There`s an old post about "Thumperdarts scoop and ? photos" from several months ago but what I did was evenly space 5 tear drop holes across the back to release pressure and my scoop is trying to rip off the car above 135+ mph and the w/b is rock solid now w/other changes to the carb also.
Re: Hood scoop pressure too much on big end. SSAH Type [Re: Thumperdart] #1616529
05/06/14 01:19 PM
05/06/14 01:19 PM
GTSDave Offline OP
GTSDave  Offline OP
Thumper,
Couldn't find that thread, but did find one where you had a couple of pics. Looks like they didn't need to be very big at all. Do you think they would work without the pan, or does it need the pan to work?
https://board.moparts.org/ubbthreads/show...amp;Search=true
mikeysmopars
Love your car. Thanks for the pics. It gives me some ideas for where to mount additional pins.
Thanks again to everyone who replied. It gives me some ideas to work with. Depending on the weather, we are planning to run in St. Louis this weekend, and if all goes well again over Memorial day for the Dave Dual Classic.
-Dave
Re: Hood scoop pressure too much on big end. SSAH Type [Re: GTSDave] #1616530
05/06/14 02:14 PM
05/06/14 02:14 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Thumper,
mikeysmopars
-Dave
That`s it...............
Re: Hood scoop pressure too much on big end. SSAH Type [Re: Thumperdart] #1616531
05/06/14 05:54 PM
05/06/14 05:54 PM
sweden
sshemi Offline
sshemi  Offline
sweden
Sorry to highjack but what gains can be expected going from a stock Hood to a glass with hemi scoop on a -68 barracuda?
Anyone ever did a somewhat fair back to back test on this?
Re: Hood scoop pressure too much on big end. SSAH Type [Re: sshemi] #1616532
05/06/14 08:52 PM
05/06/14 08:52 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
I had to put a dzus at the back of mine .
it was lifting enough at the back that I could see the carb.
