Re: heads
[Re: Cab_Burge]
#1616507
05/05/14 05:20 PM
05/05/14 05:20 PM
Posts: 1,107 Quebec, Canada
Diablo
Quebec, Canada
I'm building a new engine and trying to decide on heads. Whats the deal with B1 heads with the moved centerline? How about the Indy 572-13 heads?
The B1 with the moved centerline heads are for the bigger bore spacing blocks, not the stock blocks, I think Call Koffels(419-433-4410) and ask them
I wouldn't say they are for the bigger bore spacing blocks. Just for blocks which have bigger bores. I would saying a bore of 4.5 would be prefect for those heads. But they will fit the stock 4.8 boring spacing Chrysler block.
Re: heads
[Re: Airwoofer]
#1616509
05/06/14 01:40 AM
05/06/14 01:40 AM
Posts: 1,397 Carson City, Nevada
Biginchmopar
Carson City, Nevada
B1 = 2.300" Intake and 1.780" Exhaust B1-MC = 2.400" Intake and 1.780" Exhaust they move the exhaust valve over to fit the bigger intake valve. I believe you need to have a 4.500" bore for the B1-MC ![](/ubbthreads/images/graemlins/beer.gif)
Re: heads
[Re: copchaser]
#1616510
05/06/14 09:45 AM
05/06/14 09:45 AM
Posts: 10,019 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Even though I run 440-1 heads, I have seen so many motors with B1 stuff make more power I recommend them on anything 499 and bigger as long as you are willing to rev it past 7,000 rpm. Obviously the rpm drops with bigger motors, and a 572 with B1 heads might peak below 7200? If you go 4.5 bore then consider the B1Mc, but they are not required, just worth more hp.
Re: heads
[Re: copchaser]
#1616512
05/06/14 02:37 PM
05/06/14 02:37 PM
Diablo
Quebec, Canada
Thanks guys. Its going to be a 572, 4.500 bore. I'm leaning torwards the B1MC heads.
If your building a 572, 4.500 bore then the b1-MC are the way to go. Unless you want to move up to the Pred heads. Just depends on the power you want.
