Hey guys,
My buddy is going to select his converter for the stroker AMC and needs some advice from you off roasters/4 wheelers who mainly drive on the street but use their trucks/jeeps off road on the week-ends
Here's the thread in the 442" torque monster:
https://board.moparts.org/ubbthreads/show...e=0#Post8131633My own view is the torque (by design) is so broad and flat I would tend to keep the converter stall fairly tight (like 3200 and then try to get it to flash around 4000-4200. This way the jeep will cruise and drive "tight" and when he nails it in high gear the vert will flash right to the sweet spot.
The jeep will probably weigh 3300 w/d 3.73 gears, 33" tires and an optimum cruise speed of around 2700. I also realize that a Jeeps poor aero even at highway speeds will effectively add drag/weight to what the converter "sees" so to me that's all the more reason the cruise part throttle need to be fairly tight.
My thoughts are with such good power to weight and broad torque this motor isn't really going to care much how tight the converter stalls. I liken it to my 2600 pound 427 small block Cobra with a 5 speed, it really doesn't care what gear I'm in it'll pull right out of the basement with just the slightest tap of the throttle. To me there's not much sense putting too much stall/flash into the jeep, not with all that torque.
It's a built TH400 and a 9 1/2" converter.
Thoughts? I'm not really an off roader, but I know a little about building torque monsters
