lowering 62-65 B-body rear leafs station wagon #1615660
05/03/14 10:08 PM
05/03/14 10:08 PM
mid west
midwestmax Offline OP
mid west
need help, can anyone tell me how many leafs i should remove to get the car lowered2 - 3 inches
what i have now: 8 leafs pack on passenger side, 6 leafs on the driver side, with 1 inch lowering blocks.
still sits pretty high, running a 31.5 tall tire.. more of a street car then a drag car
any help appreciated..
thanks
- j
Re: lowering 62-65 B-body rear leafs station wagon [Re: midwestmax] #1615661
05/04/14 07:07 AM
05/04/14 07:07 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
You don't remove leafs, you install bigger blocks or alter the leafspring mountings.
Re: lowering 62-65 B-body rear leafs station wagon [Re: BigBlockMopar] #1615662
05/04/14 06:00 PM
05/04/14 06:00 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Or take some of the arch out of the springs.
Re: lowering 62-65 B-body rear leafs station wagon [Re: midwestmax] #1615663
05/04/14 06:09 PM
05/04/14 06:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I took 4 leafs out of my buddies truck to soften the
ride and lower it
Re: lowering 62-65 B-body rear leafs station wagon [Re: midwestmax] #1615664
05/04/14 09:59 PM
05/04/14 09:59 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I really don't remember how many leafs were in the springs in my '64 Polara hardtop, but my 2wd Ramcharger has only 5 on each side stock and I don't think my '87 D100 is configured like your wagon. If it were mine I would go with four each, but would start with matched, fresh springs. It is possible the PO started adding leafs to compensate for sag...or maybe you got yourself a moonshine runner
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: lowering 62-65 B-body rear leafs station wagon [Re: Polarapete] #1615665
05/04/14 10:05 PM
05/04/14 10:05 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Yes you an lower the rear by removing leafs from it, or ordering a different spring. We have done it MANY times with no ill affects as long as you do not get carried away. Not exactly a racey thing to do but will work. If this is a race deal then best bet is to go with a Mono leaf from Calvert or Landrum etc.
Re: lowering 62-65 B-body rear leafs station wagon [Re: midwestmax] #1615666
05/04/14 10:45 PM
05/04/14 10:45 PM
AndyF Offline
AndyF  Offline
Use a spring hanger with a second eye bolt hole. Mancini Racing sells them.
Re: lowering 62-65 B-body rear leafs station wagon [Re: AndyF] #1615667
05/04/14 11:02 PM
05/04/14 11:02 PM
Denison,Ia.
Cuda367 Offline
Cuda367  Offline
Denison,Ia.
My two cents. I think you people are nuts. Nothing like a mopar up in the rear 1-2 inch rake to the front and up and level on launch. Did any of you play in the sixties and early seventies. We where building mean cars then for no money when fords and chevys couldn't launch for crap. Six or 318 t-bars get the ass up and leave like no other. Now you all what to set like them and leave like them. What a waist!!! look like what ever i'll be able to see how it looks in the rear veiw mirror.
Re: lowering 62-65 B-body rear leafs station wagon [Re: Cuda367] #1615668
05/04/14 11:20 PM
05/04/14 11:20 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
So you are saying I should have had a bunch of leafs in my '64 and have it jacked up in back to be cool? To each his own...all I can say is that with the big tires in the back and a slight lowering in the front the car was a great road car with an attitude that was just right and I had no problem seeing who was chasing me...though I never got caught
2008 Honda Element
