Made it to the track last weekend...UPDATE 8.45 @ 160
#1615024
05/02/14 01:22 PM
05/02/14 01:22 PM
Posts: 916 SE Washington
Forest
SE Washington
So the new motor trans combo has 9 full passes on it. 4 on Saturday and 5 on Sunday. Sunday was the 1st points race and I only got one time trail, but was fortunate enough to make it to the semi-finals before losing concentration and giving away a final round appearance on the tree.
Car went a best of 8.61 at 156 with a 1.19 60'.
I think it has a easy .50 in it if not a 8.40...
Re: Made it to the track last weekend...
[Re: Whompin_Wedge]
#1615027
05/02/14 01:56 PM
05/02/14 01:56 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Congrats, glad it went well.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: Forest]
#1615029
05/02/14 08:09 PM
05/02/14 08:09 PM
Posts: 9,863 MI, usa
dvw
MI, usa
I need to do a bit of shock wheelie bar tuning, but the car went right down the track. Sunday it was between .61 & .64 with weather changes too.
Also need to work on oil getting sucked into the vacuum pump. One thing I'll start doing for sure is kill the motor at the stripe. Thinking that will make a big difference as well as tune on the baffel.
I run an Indy head and not a B-1. But since the vacuum pump outlet was moved to the front of the right valve cover I can run a couple events without emptying the bottle. Doug
[Re: Triple Threat]
#1615033
05/04/14 01:47 PM
05/04/14 01:47 PM
Forest
SE Washington
When are you bringing it to sea level?
Got me we have a busy summer, Plan to go to the Woodburn Mopar Nats, but the DA isn't always great that weekend.
[Re: Chris2581]
#1615037
05/04/14 08:40 PM
05/04/14 08:40 PM
Quicktree
You've done a nice job on that car,and it runs very well.
[Re: Al_Alguire]
#1615043
05/12/14 01:36 PM
05/12/14 01:36 PM
Triple Threat
Renton Washington
Getting better! Might even like more than 35 degrees of timing.
