wanting to put led lights in my 69 truck #161493
12/05/08 02:05 AM
12/05/08 02:05 AM
spokane/pullman Wa
ryanf Offline OP
ryanf  Offline OP
spokane/pullman Wa
Hello, i have a 69 dodge d100 that i am fixing up and i picked up a kwik wire 22 circuit wiring harness to rewire the truck. and i am wanting to replace the bulbs with leds so i will be seen and see better. My question is where do you go for the leds and what would you recommend and what problems did you face? also what headlights and instrument panel leds would be good? and what numbers do i need to get?
Ryan
Re: wanting to put led lights in my 69 truck [Re: ryanf] #161494
12/05/08 04:19 AM
12/05/08 04:19 AM
California
cudagee Offline
cudagee  Offline
California
Hi, you can check out this link
www.hitechledproducts.com
818 887-0136
You can send your taillights and they can convert it for you
John
