Page 3 of 48 1 2 3 4 5 47 48
Re: Modern Bullitt build [Re: Keepat] #1614721
08/21/14 10:46 PM
08/21/14 10:46 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I’m still working on the colors but I think it is close to the original hub cap colors. I also ordered the motor today, an aluminum gen III 6.1 Hemi stroked to 426 ci and about 650 hp
Pat
Re: Modern Bullitt build [Re: Keepat] #1614722
08/22/14 11:14 AM
08/22/14 11:14 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Those wheels are awesome even though I am not a fan of large dia wheels on musclecars. One of my dream cars is to also have a Bullit Clone 68 Charger someday. I'll bet those were not cheap.... Awesome decision to have them made.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Modern Bullitt build [Re: 6PKRTSE] #1614723
08/29/14 11:22 PM
08/29/14 11:22 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I finished the rust repair on the right side quarter panel, it required 3 small patch panels and a little fender well repair. The trunk floor extensions have some pits but require no repair just a coat of POR 15.
Pat
Re: Modern Bullitt build [Re: Keepat] #1614724
08/29/14 11:42 PM
08/29/14 11:42 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I also had the tires mounted on the new wheels but I have yet to cut in the mini tub so I had to put the front wheels on the rear for pictures as the 12” wheel with the 335 tire don’t fit the car yet.
Pat
Re: Modern Bullitt build [Re: Keepat] #1614725
08/31/14 03:52 PM
08/31/14 03:52 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I plan on testing a 3/16 black line on the outer rim as it is on the original hub cap. I’m having 17 7/8”x 3/16 vinyl ring made to check the look.
Re: Modern Bullitt build [Re: Keepat] #1614726
09/02/14 10:49 PM
09/02/14 10:49 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I installed a vinyl black ring on one of the wheels to match the black line on the hub caps and I like the look. Hard to see the black line in the pictures but I think it finishes the look of the wheel.
Pat
Re: Modern Bullitt build [Re: Keepat] #1614727
09/13/14 08:21 PM
09/13/14 08:21 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Received my dash and door pads from Just Dashes and they look great. This is the 2nd Charger dash and door pads they have done for me just wish they could replicate the stiching :-( here are a few before and after pictures
Pat
Re: Modern Bullitt build [Re: Keepat] #1614728
09/20/14 12:06 AM
09/20/14 12:06 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Finished the rear valance and left rear quarter rust repair. One more rust spot on the front side of the left quarter to do then on to the trunk floor.
Re: Modern Bullitt build [Re: Keepat] #1614729
09/23/14 10:34 PM
09/23/14 10:34 PM
Harm City Md.
Dan Halen Offline
Dan Halen  Offline
Harm City Md.
I've seen your old silver car,
This one will be even better!
Re: Modern Bullitt build [Re: Dan Halen] #1614730
09/24/14 07:56 PM
09/24/14 07:56 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
The silver Charger was a fun car to build that why I'm doing another one! Did you see the silver charger in person?
Thanks!
Pat
[IMG]http://i264.photobucket.com/albums/ii196/keepat/carstuff001.jpg~original[/IMG]
Re: Modern Bullitt build [Re: Keepat] #1614731
10/20/14 06:34 PM
10/20/14 06:34 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Received a few pictures of the motor Indy is building for the charger. As soon as the 2nd FAST throttle body shows up I will drive out for the Dyno and bring it home.
Pat
Re: Modern Bullitt build [Re: Keepat] #1614732
10/20/14 11:59 PM
10/20/14 11:59 PM
That looks pretty.
Re: Modern Bullitt build [Re: Keepat] #1614733
10/21/14 12:09 AM
10/21/14 12:09 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
OoooOoooooOoo... Shiny.
Re: Modern Bullitt build [Re: Keepat] #1614734
10/23/14 12:23 AM
10/23/14 12:23 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I de-torsion bar the charger, as I’m going to use RMS coil over front suspension.
Pat
Re: Modern Bullitt build [Re: Keepat] #1614735
10/28/14 11:09 PM
10/28/14 11:09 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Added a cross member just forward of the leaf spring mounts. Used a 2” x 1 ¼” “C” channel cut and welded to fit in the floor tunnel under the rear seat. This should add additional rigidity to the chassis without impeding the driveshaft. Torque boxes are next.
Pat
Re: Modern Bullitt build [Re: Keepat] #1614736
10/29/14 01:55 AM
10/29/14 01:55 AM
Nice work.
Re: Modern Bullitt build [Re: Keepat] #1614737
11/07/14 11:50 AM
11/07/14 11:50 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Drove to Reilly Motorsports yesterday to pick up the front and rear suspension for the charger. Bill Reilly is a great guy and he had everything ready for pickup! Also stopped in Hazleton PA for the best chili dogs at Jimmy’s! I will post a few more picture of the RMS part when I get them out of the boxes.
Pat
Re: Modern Bullitt build [Re: Keepat] #1614738
11/09/14 05:06 PM
11/09/14 05:06 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Assembled the shocks using anti-seize and chased the threads on the upper control arms. Nice working on clean new stuff instead of old rusty stuff.
Pat
Re: Modern Bullitt build [Re: Keepat] #1614739
11/13/14 01:24 AM
11/13/14 01:24 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I assemble the new front wheel hubs, hats and the rotors. I used the same Wilwood 13” 6 piston brakes on my last 68 Chargers and they worked great!
Pat
Re: Modern Bullitt build [Re: Keepat] #1614740
11/14/14 12:47 AM
11/14/14 12:47 AM
CO
I
ihv800 Offline
ihv800  Offline
I
CO
Build looks awesome. What is your procedure for metal finishing your welds down on the patch work? It looks fantastic!
