Page 1 of 48 1 2 3 47 48
Modern Bullitt build #1614681
05/01/14 07:58 PM
05/01/14 07:58 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I started the restoration of my 1968 Dodge Charger with a plan to build a modern Bullitt. The outside of the car will look like the movie car with exception to the wheels, tires and a lower stances.
I’m planning on a set of one off 17” wheels to match the look of the hubcaps use on the Bullitt Charger. This will allow larger brakes and wider tires. This hubcap was made to look like a mag wheel and now
I’m going to have a wheel made to look like a hubcap. The motor will be a gen III Hemi 6.4 or the new Hellcat if it would fit under the stock hood? And a 6 speed manual trans. I have a lot of details to work out but for now
I will bag and tag the parts and get the car media blasted.
Pat
This how car looked when I bought it a 1 ½ years ago.
And now the parts start coming off!
Re: Modern Bullitt build [Re: Keepat] #1614682
05/02/14 12:39 PM
05/02/14 12:39 PM
Salt Lake City, UT
Turbo224 Offline
Turbo224  Offline
Salt Lake City, UT
Looks like a pretty clean car to start your project with. Looking forward to pictures!
Tyler Larsen~Salt Lake City -1971 Plymouth Cuda 440-6pk Tribute -1992 Dodge Daytona IROC R/T -1989 Shelby CSX-VNT #153
Re: Modern Bullitt build [Re: Turbo224] #1614683
05/02/14 03:39 PM
05/02/14 03:39 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I like the concept! I'll be watching.
Re: Modern Bullitt build [Re: Keepat] #1614684
05/05/14 12:47 PM
05/05/14 12:47 PM
Texarkana tx
Duster08 Offline
Duster08  Offline
Texarkana tx
Sweet ride
Re: Modern Bullitt build [Re: Duster08] #1614685
05/21/14 10:07 AM
05/21/14 10:07 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Still bagging and tagging the charger so I can get the car to the media blaster. Overall the car is in great shape with all of its original sheet metal and no accidents. The front fenders have never been off the car as I had to remove the great factory undercoating to get to the fasteners for the splash guards. The media blaster I’m sure will uncover a few surprises. But for now here is the Good the Bad and the Ugly to date.
The Good, all of the frame rails are in excellent condition with only one small area of rust on the right side trans cross member and no accidents front or rear.
The Bad, a little rust on the driver’s side floor that will take an 8” x 12” patch panel
And the Ugly, I knew I would be replacing the trunk floor when I bought the car, but the back yard patch job is Ugly! On the good side both trunk drop and frame rails are rust free.
Pat
Re: Modern Bullitt build [Re: Keepat] #1614686
05/21/14 11:06 PM
05/21/14 11:06 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I received the 1st rendering of the custom wheel I’m having made to look like the hubcaps used on the Bullitt Charger. There are a few small changes that need to be made, such as the center emblem is not orientated correctly. There will be a tool that will fit the emblem which will allow access to the lug-nuts. I’m very happy with the 1st drawings of this one off wheel and look forward to seeing them made.
This is the original hubcap
And here is the custom version of the hubcap
Pat
Re: Modern Bullitt build [Re: Keepat] #1614687
05/22/14 08:47 AM
05/22/14 08:47 AM
New Kent, Va.
bobbyb Offline
bobbyb  Offline
New Kent, Va.
Cool I like the wheels.
2004 Dodge Rumble Bee 5.7 Hemi
1969 Plymouth Roadrunner
Re: Modern Bullitt build [Re: bobbyb] #1614688
05/22/14 01:25 PM
05/22/14 01:25 PM
Oakley CA
69charger440_6pa Offline
Oakley CA
Great job on the wheels, I like them alot!! Can't wait to see this car come together. I loved your last car, lots of inspiration for my current build is coming from your old ride.
1969 Charger R/T under construction
2014 Ram 3500 Cummins
2006 Corvette Z06
2015 Corvette Z06
2014 BMW M5
Re: Modern Bullitt build [Re: 69charger440_6pa] #1614689
05/23/14 10:21 PM
05/23/14 10:21 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Yeah I enjoyed that first charger so much I decided to do it again, this one I'm sure will be a lot easier because the first one was a basket case as it was already disassembled before I bought it.
Thank you!
Pat
Re: Modern Bullitt build [Re: Keepat] #1614690
05/23/14 11:51 PM
05/23/14 11:51 PM
CO
I
ihv800 Offline
ihv800  Offline
I
CO
I've dreamt of building a Bullitt Charger for a long time. I've tossed plans around on what to do about wheels. I like the looks of the wheel covers, but am a bigger fan of styled wheels. I always thought how awesome it would be to have some custom wheels made that mimicked the full wheel covers. Those will be sweet, and in my opinion make the look of the car! Look forward to all you do to it.
Re: Modern Bullitt build [Re: ihv800] #1614691
05/24/14 12:24 PM
05/24/14 12:24 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I have been trying to restore the parts as I remove them instead of at the end of the project. The left side vent box is the last item I did and it cleaned up nicely. Here are a few before and after pictures.
Thanks!
Pat
Re: Modern Bullitt build [Re: Keepat] #1614692
05/27/14 11:54 PM
05/27/14 11:54 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Received a few more wheel drawing with the logo upright and the black around the cut outs removed. Next drawings will have the extra material remove that was black as I think it may look better??
This is the front wheel 17x9 with a 5 ½” back space
And this is the back wheel 17x11 with a 6 ½” back space
Pat
Re: Modern Bullitt build [Re: Keepat] #1614693
05/28/14 08:15 PM
05/28/14 08:15 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
This is the final design of the wheel and the order is in! No black in the openings and the openings are larger. I should see them in 6 to 8 weeks.
Thanks!
Pat
Re: Modern Bullitt build [Re: Keepat] #1614694
05/28/14 08:22 PM
05/28/14 08:22 PM
Moncton, New Brunswick
hemidart1 Offline
hemidart1  Offline
Very cool
1967 Hemi GTX
1969 Chrysler 300
Re: Modern Bullitt build [Re: Keepat] #1614695
05/28/14 10:51 PM
05/28/14 10:51 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Love the wheels and restoring the parts when pulling them is the best strategy to avoid getting overwhelmed when the car is all apart and everything is dirty. That's why projects sit for years and then get sold.
Sheldon
Re: Modern Bullitt build [Re: RUNCHARGER] #1614696
05/29/14 08:29 PM
05/29/14 08:29 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Disassembled both doors so I can send out the vent window and door handles for re-chroming. Here are a few picture of the left doors hardware cleaned and painted along with the right doors hardware as it came out.
I remembered from my last 68 charger that reproduction the tail light gaskets didn’t fit well. This time I was able to remove the original gasket without much damage and used an upholstery steamer to expand the foam. Then I sprayed a few coats of Plasti-Dip to fill in any damage. They should work like new!
Pat
Re: Modern Bullitt build [Re: Keepat] #1614697
06/08/14 10:50 PM
06/08/14 10:50 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Still removing and restoring as I go, but not much photogenic stuff to post. One of the things I restored was the rearview mirror and I took a few pictures of my sons 68 mustang with it.
Soon my Charger will look as good as his Fastback but it will be a lot faster ;-)
Thanks!
Pat
Re: Modern Bullitt build [Re: Keepat] #1614698
06/13/14 07:55 PM
06/13/14 07:55 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Received my tires yesterday, 255/45 and 335/35. Hope to get the wheels in a few weeks, then I can test
fit the front wheel/tires but will have to wait until I mini tub the rear to see the back wheels/tires under the car.
Thanks!
Pat
Re: Modern Bullitt build [Re: Keepat] #1614699
06/18/14 06:35 PM
06/18/14 06:35 PM
California
mickm Offline
mickm  Offline
California
those 355's are massive! how do you plan on getting them under there, are you going to mini tub it?
Re: Modern Bullitt build [Re: mickm] #1614700
06/20/14 08:10 PM
06/20/14 08:10 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Yes, mini tub and RMS 4 link. As the trunk is rusted and is the only part of the floor that needs to be replaced that'll give me the room to work in the tubs with the old floor out.
Pat
