Re: Modern Bullitt build
[Re: larry4406]
#2997248
12/21/21 10:21 AM
12/21/21 10:21 AM
Posts: 676 Maryland
Keepat
Maryland
Nice shop Pat!
I like those lights. What are they?
Big Ass fan is a nice addition.
Jackshaft door operators as well!
What is the size? Ceiling looks to be 12-14'?
Exterior shot?
Keep us posted on your next project.
-larry LED 4x2 panel lights, I’ll let you know how they work. https://www.amazon.com/dp/B0849TG3B3/ref=tsm_1_tp_tcThe shop is 48’x32’ with 13’ ceiling just enough room for the tall two post lift. Thank You!
[Re: Keepat]
#2997870
12/23/21 01:41 PM
12/23/21 01:41 PM
Posts: 1,703 central il.
second 70
central il.
Nice shop Pat!
Exterior shot?
-larry LED 4x2 panel lights, I’ll let you know how they work. https://www.amazon.com/dp/B0849TG3B3/ref=tsm_1_tp_tcThe shop is 48’x32’ with 13’ ceiling just enough room for the tall two post lift. Thank You! Hey Keepat I really can't tell on your both your doors but the lower panels on the left door seem to be bent in the middle. I had the same thing and it's the door bending in the middle when it opens. It will end up tearing the panels open. I didn't have a clue since I use the same jackshaft openers you do. I didn't catch it until I unhooked it and operated it by hand. The fix is to add struts to door. At less that $25 each I just added them to each panel.
[Re: second 70]
#2997970
12/23/21 06:09 PM
12/23/21 06:09 PM
Posts: 676 Maryland
Keepat
Maryland
Nice shop Pat!
Exterior shot?
-larry LED 4x2 panel lights, I’ll let you know how they work. https://www.amazon.com/dp/B0849TG3B3/ref=tsm_1_tp_tcThe shop is 48’x32’ with 13’ ceiling just enough room for the tall two post lift. Thank You! Hey Keepat I really can't tell on your both your doors but the lower panels on the left door seem to be bent in the middle. I had the same thing and it's the door bending in the middle when it opens. It will end up tearing the panels open. I didn't have a clue since I use the same jackshaft openers you do. I didn't catch it until I unhooked it and operated it by hand. The fix is to add struts to door. At less that $25 each I just added them to each panel. Thanks for the note, and good eyes! Actually the bottom panel is bent from the previous owner closing the door by stepping on that lip. My garage door opener man is coming back as soon as I put a coat of paint on the outside of the door to readjust the springs for the new weight of the doors. Thank You! Pat
[Re: Keepat]
#3016754
02/19/22 12:48 PM
02/19/22 12:48 PM
second 70
central il.
Pat, I use the Mitsubishi split units in my garage and great room. I spent a little extra and got the H2i hyper heat pump so it would work if weather got super cold. 100% @ 5 and 74% @ -13. Even so they work so much better above 32 and for air. My inside units are the fancy 9K and 18K that work off the 1 outside multi zone 24BTU unit. Is yours multi zone or do you have 2 outside units? Are you using it for heat and air or just air? These are the units I have. https://skipthewarehouse.com/mitsubishi-mxz3c24nahz2u1-24000-btu-hyper-heat-heat-condenser Great looking garage. Mike
[Re: larry4406]
#3017027
02/20/22 08:54 AM
02/20/22 08:54 AM
Posts: 676 Maryland
Keepat
Maryland
Nice shop Pat!
Color me green with envy. Thank You sir!
[Re: second 70]
#3017028
02/20/22 08:58 AM
02/20/22 08:58 AM
Posts: 676 Maryland
Keepat
Maryland
Pat, I use the Mitsubishi split units in my garage and great room. I spent a little extra and got the H2i hyper heat pump so it would work if weather got super cold. 100% @ 5 and 74% @ -13. Even so they work so much better above 32 and for air. My inside units are the fancy 9K and 18K that work off the 1 outside multi zone 24BTU unit. Is yours multi zone or do you have 2 outside units? Are you using it for heat and air or just air? These are the units I have. https://skipthewarehouse.com/mitsubishi-mxz3c24nahz2u1-24000-btu-hyper-heat-heat-condenser Great looking garage. Mike Mike, The Mitsubishi mini split‘s are amazing units so efficient and produce heat in very low temperatures where traditional heat pumps struggle. I have a single 36K unit outside feeding the two 18k air handler‘s Thanks Pat
[Re: 69Cuda340S]
#3018499
02/24/22 02:48 PM
02/24/22 02:48 PM
Posts: 10,203 Someplace you aren't
SomeCarGuy
I use a lot of Sunpro lights, they are awesome. I’ve not used the flat panels yet. I just put up some of their other shop lights this past fall and already bought enough to do the other bay. They really look good.
The power tour with the bullitt duo is off the hook. Mega kudos on that.
I want my fair share
[Re: 69Cuda340S]
#3018612
02/24/22 07:30 PM
02/24/22 07:30 PM
Posts: 676 Maryland
Keepat
Maryland
That new shop is awesome! Thank You sir!
[Re: SomeCarGuy]
#3018613
02/24/22 07:32 PM
02/24/22 07:32 PM
Posts: 676 Maryland
Keepat
Maryland
The power tour with the bullitt duo is off the hook. Mega kudos on that. I am also very happy with the shop lights. Was concerned that they would be too bright so I put them on three different switches. Thank You! Pat
