Page 20 of 48 1 2 18 19 20 21 22 47 48
Re: Modern Bullitt build [Re: Keepat] #2231130
01/09/17 10:18 PM
01/09/17 10:18 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Larry,
The shop has 2 electric baseboard heater that keep the shop right around 60°, you can see one mounted just above the row of lights in the third picture above. Fortunately my shop rent includes the electric ;-)
Thank you
Pat
Re: Modern Bullitt build [Re: Keepat] #2234740
01/15/17 04:16 PM
01/15/17 04:16 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Scored a nice 68 console Inland shifter on craigslist. My plan is to cut the base off and modify the shifter for my T 56 six speed using the T handle to engage a micro switch to operate the electronic reverse shut out on the T56
Pat
Re: Modern Bullitt build [Re: Keepat] #2236639
01/18/17 12:41 PM
01/18/17 12:41 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
I'm really looking forward to seeing this car, painted, and the assembly progress. yet, I'll be kinda bummed when it's all done. The detail, and seeing the work put into it, has been interesting. Keep up the good work.
BTW, you make me feel lazy LOL.
69 GTX 68 Road Runner
Re: Modern Bullitt build [Re: JERICOGTX] #2236826
01/18/17 05:25 PM
01/18/17 05:25 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
My thoughts exactly... This car reminds me of a "riddler award" car.. So many hidden aspects to it...
I say this due to watching Chip Foose describe his "riddler" winning car one time... So many things you just don't realize until it is shown to you...
Re: Modern Bullitt build [Re: JERICOGTX] #2237506
01/19/17 09:16 PM
01/19/17 09:16 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Thank You sir!
Re: Modern Bullitt build [Re: minivan] #2237508
01/19/17 09:17 PM
01/19/17 09:17 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Thank you!!
Pat
Re: Modern Bullitt build [Re: Keepat] #2237519
01/19/17 09:36 PM
01/19/17 09:36 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I epoxy sealed, base coated, and cleared the bottom of the car today
Thank you!
Pat
Re: Modern Bullitt build [Re: Keepat] #2256310
02/19/17 11:27 PM
02/19/17 11:27 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Landing gear is on and she will be on the ground soon. Then I'll hang the doors, fender, hood and trunk to set & correct the gaps.
Pat
Re: Modern Bullitt build [Re: Keepat] #2257194
02/21/17 03:33 PM
02/21/17 03:33 PM
Maryland
rhamson Offline
rhamson  Offline
Maryland
Looking good Pat. Keep up the good work!
Re: Modern Bullitt build [Re: rhamson] #2258401
02/23/17 11:33 PM
02/23/17 11:33 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Thank you sir! FYI Alex bought a 1970 Cuda for his next project.
Pat
Re: Modern Bullitt build [Re: Keepat] #2261690
03/01/17 04:24 PM
03/01/17 04:24 PM
Maryland
rhamson Offline
rhamson  Offline
Maryland
Love Cuda's.
Re: Modern Bullitt build [Re: Keepat] #2265967
03/09/17 01:32 AM
03/09/17 01:32 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Off the rotisserie and on four wheels ;-)
Pat
Re: Modern Bullitt build [Re: Keepat] #2267658
03/11/17 09:25 PM
03/11/17 09:25 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Had to do a little metal work on the passenger door before I could hang it.
Pat
Re: Modern Bullitt build [Re: Keepat] #2268009
03/12/17 02:16 PM
03/12/17 02:16 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
The subject of small dings and dents was brought up, so I thought I would post a few pictures of how an old body man showed me an easy technique to work them out if you have access to the other side. Using a spring-loaded center punch with a filed down blunt end.
Start with locating and marking the dent from the backside. Then unscrew the spring-loaded center punch a few turns as to lessen the blow for the first try. It may take two or three strikes to get the panel flush, along with changing the tension on the spring loaded center punch. You may need to move the impact point a 16th of an inch in either direction to work the dent out.
Pat
Re: Modern Bullitt build [Re: Keepat] #2268487
03/13/17 09:38 AM
03/13/17 09:38 AM
mopar4don Offline
mopar4don  Offline
Hey Nice tip Pat, And thank you for sharing.
Say what is that on the inside of the door? Something to cushion the blow of the center punch?
Re: Modern Bullitt build [Re: mopar4don] #2268498
03/13/17 10:31 AM
03/13/17 10:31 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Don,
That is just an optical illusion, I scraped away some of the sound deadening on the inside of the door so that the punch would make direct contact with the metal.
Pat
Re: Modern Bullitt build [Re: Keepat] #2268504
03/13/17 10:52 AM
03/13/17 10:52 AM
mopar4don Offline
mopar4don  Offline
Don,
Pat
Ahhh, I see it now!
Re: Modern Bullitt build [Re: Keepat] #2269226
03/14/17 11:22 AM
03/14/17 11:22 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
With the right side fender hung she is starting to look like a charger again :-)
Pat
Re: Modern Bullitt build [Re: Keepat] #2269338
03/14/17 02:16 PM
03/14/17 02:16 PM
Boca Raton, Florida
jpilone Offline
jpilone  Offline
Boca Raton, Florida
Awesome work!! You should sell your services for the steering wheel!!
-Jarrod Pilone
'70 Plymouth RR Convertible with amazing custom paint(Tribute/Recreation/Whateveryouwannacallit)
My Project Thread
Re: Modern Bullitt build [Re: jpilone] #2269476
03/14/17 06:15 PM
03/14/17 06:15 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
If I did that my hobby would become a job and I already have 1 job and not looking for another ;-)
Pat
