Scatter sheild bellhousing starter placement #1614551
05/01/14 08:53 AM
05/01/14 08:53 AM
Central Pa. U.S.A.
Bigfury Offline OP
Bigfury  Offline OP
Central Pa. U.S.A.
Installed a 130 tooth aluminum flywheel along with an aftermarket scatter shield. This all went on a 400 block. Anyhow none of the predrilled mount hole for the starter would work. Drilled another set of holes. Now it's going to take machine work to get the end support, of the starter, to mount into the bellhousing. My question is what kind of problems my occur with out this support in place? The engine is below 11 to 1 compression. Like they say if you want to play your gone ah pay.
Re: Scatter sheild bellhousing starter placement [Re: Bigfury] #1614552
05/01/14 09:04 AM
05/01/14 09:04 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Lakewoods use an extension for the 130 wheel.It moves the starter over.With a 143 wheel it bolts right in.Rocky
Chrysler Firepower
Re: Scatter sheild bellhousing starter placement [Re: therocks] #1614553
05/01/14 11:54 AM
05/01/14 11:54 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
IIRC that extension is just a short piece of flat bar with two holes in it and it comes in the snout kit.
