Anyone work at a Ram dealer? #1614260
04/30/14 07:01 PM
04/30/14 07:01 PM
Pittsburgh PA
Eric Offline OP
Eric  Offline OP
Pittsburgh PA
I need two seat parts and one is discontinued. I need the seat cushion part #5180021AA and the discontinued seat cover part #1FM411J3AA....thanks folks
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Anyone work at a Ram dealer? [Re: Eric] #1614261
04/30/14 07:06 PM
04/30/14 07:06 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Tried Google?
- Stu Harmon
Re: Anyone work at a Ram dealer? [Re: feets] #1614262
04/30/14 07:11 PM
04/30/14 07:11 PM
ND
dodgedon Offline
dodgedon  Offline
ND
5180021AA. They are on Ebay. I show 29 dealers have 1 in stock also.
The 1FM411J3AA no luck....sorry
67 Charger 383 auto
75 Dodge CNT 800 CAT Diesel
2012 Ram Crew cab 5.7 4x4
Re: Anyone work at a Ram dealer? [Re: feets] #1614263
04/30/14 08:31 PM
04/30/14 08:31 PM
Pittsburgh PA
Eric Offline OP
Eric  Offline OP
Pittsburgh PA
Tried Google?
. Um yep . The discontinued cover is the issue. Thanks for the info Dodgem
Re: Anyone work at a Ram dealer? [Re: Eric] #1614264
04/30/14 09:44 PM
04/30/14 09:44 PM
Sault Ste. Marie, Ontario, Can...
moparmike1 Offline
moparmike1  Offline
Just a suggestion but for a damaged driver's seat, I found the matching passenger seat on eBay. Bought I, brought both to a local upholstery shop where they replaced the damaged panels with the good ones from the new seat. The panels were the same regardless of which side the seat was meant for.
Don't know if this would work for you but thought I would mention it.
Good luck,
Mike.
Re: Anyone work at a Ram dealer? [Re: Eric] #1614265
04/30/14 10:15 PM
04/30/14 10:15 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
Eric is that a bucket seat bottom cover?
I have a new one with 13248 stenciled on it, no other markings I can find. The orig box is long gone but it was from the dealer for a "newer" Dodge truck.
EDIT:
here's a picture of it...
Re: Anyone work at a Ram dealer? [Re: nomore65BelvJim] #1614266
05/01/14 12:41 AM
05/01/14 12:41 AM
ND
dodgedon Offline
dodgedon  Offline
ND
I looked again at your numbers and that 1FM411J3AA part... What is this? The description says "Front Seat Cushion" Are you looking for a cover? The 518 number looks to be the foam... IS this correct?
67 Charger 383 auto
Re: Anyone work at a Ram dealer? [Re: dodgedon] #1614267
05/01/14 10:09 AM
05/01/14 10:09 AM
Pittsburgh PA
Eric Offline OP
Eric  Offline OP
Pittsburgh PA
Yes I need the cushion and the cover..
Re: Anyone work at a Ram dealer? [Re: Eric] #1614268
05/01/14 11:53 PM
05/01/14 11:53 PM
ND
dodgedon Offline
dodgedon  Offline
ND
The numbers you gave each say cushion? I guess this is what I was trying to ask.... Are you sure you have the right number for the cover? It may just be a typo on the system but both numbers say "cushion" in the description not "cover"?
67 Charger 383 auto
Re: Anyone work at a Ram dealer? [Re: Eric] #1614269
05/02/14 12:05 AM
05/02/14 12:05 AM
Lehigh Acres, Florida
rickstershemi Offline
ck with a local auto upholsterer they do work for auto dealers all the time and can replicate damn near anything....
Rickster
