Re: Engine runs on
[Re: RSNOMO]
#1613996
04/29/14 11:54 PM
04/29/14 11:54 PM
Posts: 1,526 North Carolina
cjskotni
North Carolina
Few things come to mind that can cause this: - try more timing, maybe 14-16* initial - running excessively lean causing hot cylinders - richen up mixture - idle speed too high Could be either of these things or some combination thereof. Good luck!
Re: Engine runs on
[Re: RapidRobert]
#1614000
04/30/14 01:42 AM
04/30/14 01:42 AM
Posts: 12,271 Overpriced Housing Central
RobX4406
10* initial timing... nope no potential issue there. I run stock 318's with more initial timing! Fix the initial timing to what the engine wants, re-tune the carbs and go from there. It will take some changes to the distributor internals. Simple, grab distributor, twist it a bit CW, if it picks up RPM, it wants the timing. How big of a cam is in this thing?
Re: Engine runs on
[Re: RobX4406]
#1614002
04/30/14 01:47 AM
04/30/14 01:47 AM
RapidRobert
I missed that, what Rob said it definitely needs more than 10
Re: Engine runs on
[Re: 71birdJ68]
#1614005
04/30/14 01:59 AM
04/30/14 01:59 AM
RapidRobert
I'd start with the tried & true "vac gauge" method: keep advancing the timing till you reach max vac all the while reducing the idle speed back to the lowest point it will idle in gear at then reduce the timing till the vac drops (1) in hg & that is the ideal initial timing if it does not kick back when starting. If so you can either add an on/off ign switch & get it cranking with the regular ign switch then switch on the auxillary ign sw so it gets power & will fire or reduce the initial 1 degree & retry and another 1 degree if needed
Re: Engine runs on
[Re: 71birdJ68]
#1614009
04/30/14 12:50 PM
04/30/14 12:50 PM
Posts: 5,163 CT
GTX MATT
CT
Carbs are off the idle circuit, more timing, less idle RPM/curb idle adjustment
Re: Engine runs on
[Re: GTX MATT]
#1614010
04/30/14 08:31 PM
04/30/14 08:31 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
If it still gives you problems after the tune is right then I would consider an idle solenoid so it can let the throttle close more at key off. Also if its an auto shut the eng off in gear or if its a stick just let the clutch out when you shut the eng off. Just let the clutch out enough to grab a bit and stall the eng. They are not the real world fixes but many hotrods with large cams idle higher and the popping of the clucth or shut it off in gear helps. Ron
Re: Engine runs on
[Re: 71birdJ68]
#1614012
04/30/14 09:11 PM
04/30/14 09:11 PM
Posts: 259 Khemi, Stygia
Mebsuta
Khemi, Stygia
Mine (383 HP) used to run on with lesser grades of gasoline (less than 91 octane). Try the highest grade of gasoline you can get.
Also, the E10 everywhere now helps me. I can actually run 87 or 89 without pinging or running on.
68 Roadrunner. 383 4-spd. Beat up.
Re: Engine runs on
[Re: 71birdJ68]
#1614013
04/30/14 11:44 PM
04/30/14 11:44 PM
RapidRobert
Where can I find one of those solenoids?
I ain't sure what year(s) they came on. An ad in the wanted section(s) here would likely produce a good used one. EDIT Or eBay might be faster
