Page 3 of 3 1 2 3
Re: Milodon SB 8 quart pan vs. 7 quart lowpro pan? [Re: BPE] #1613817
04/30/14 11:46 PM
04/30/14 11:46 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Big 4"
Why not just run the same pan and an oil cooler?
Rod
LOL Rod, get your mind outta the gutter!
I don't want to run a cooler, not a fan of the idea to be honest.
This whole thread really begs the question though- how much oil does one really need to run? Many only run 6 quarts in deep 7 or 8 qt pans...This is a street car and strip, but is the Kevko pan enough, atleast with a standard volume pump? It would seem to me no, but I am no expert
Re: Milodon SB 8 quart pan vs. 7 quart lowpro pan? [Re: mshred] #1613818
05/01/14 12:04 AM
05/01/14 12:04 AM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I have been running the Kevco pan for 2 years and probably 200 passes at 6800 with a standard pump and I have had no issues so far. I just upgraded my fuel system and i will probably go up to 7000 rpm. Mine is 3.79 stroke 394 ci.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Milodon SB 8 quart pan vs. 7 quart lowpro pan? [Re: D-50] #1613819
05/01/14 12:35 AM
05/01/14 12:35 AM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
How much oil do you run in the pan? in the filter?
I have thought about keeping the kevko, running a standard volume pump again, and seeing what happens when I hit 7000rpm on a regular basis on nitrous...But I am worried at the same time about what could happen
Re: Milodon SB 8 quart pan vs. 7 quart lowpro pan? [Re: mshred] #1613820
05/01/14 09:12 AM
05/01/14 09:12 AM
Indy
FlyFish Offline
FlyFish  Offline
Indy
I run mine with 6-6.5 quarts.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: Milodon SB 8 quart pan vs. 7 quart lowpro pan? [Re: mshred] #1613821
05/01/14 11:23 AM
05/01/14 11:23 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Well if I hadn't sold my Milodon low pro pan for my 360 I'd go run your "fill it with water test" just for kicks...
Re: Milodon SB 8 quart pan vs. 7 quart lowpro pan? [Re: mshred] #1613822
05/01/14 12:00 PM
05/01/14 12:00 PM
Az
Crizila Offline
Crizila  Offline
Az
I run 7 qts in my 30940 ( 8 qt pan ). Small oil filter to clear headers. I also run a windage tray. My block is filled, so oil temp can be an issue. I run an oil temp gauge as well as oil pressure. Go through the lights at around 7K and always good pressure. Running 7 qts is a SAFE quantity for me. You only get to run out once at 7K .
Fastest 300
Re: Milodon SB 8 quart pan vs. 7 quart lowpro pan? [Re: mshred] #1613823
05/01/14 09:26 PM
05/01/14 09:26 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Milodon 8 qt pan.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Milodon SB 8 quart pan vs. 7 quart lowpro pan? [Re: 1967dartgt] #1613824
05/01/14 09:27 PM
05/01/14 09:27 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Re: Milodon SB 8 quart pan vs. 7 quart lowpro pan? [Re: 1967dartgt] #1613825
05/01/14 09:28 PM
05/01/14 09:28 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Milodon 8 qt pan.
Custom headers? Or TTI?
Re: Milodon SB 8 quart pan vs. 7 quart lowpro pan? [Re: FlyFish] #1613826
05/01/14 09:30 PM
05/01/14 09:30 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
I have been told that with filter and pan a kevko can hold 6 quarts
Really though, what is "enough" is the question?
Re: Milodon SB 8 quart pan vs. 7 quart lowpro pan? [Re: mshred] #1613827
05/01/14 10:28 PM
05/01/14 10:28 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I am running 5 1/2 right now. I will probably run 6 if I up the RPM's.
Re: Milodon SB 8 quart pan vs. 7 quart lowpro pan? [Re: mshred] #1613828
05/02/14 01:45 AM
05/02/14 01:45 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Milodon 8 qt pan.
Custom headers, none made for W9 heads. And I run 8 qts with remote filter and 12 an lines. And I would much rather hit my oil,pan then my headers, it's a lot cheaper to replace oil pans.
Re: Milodon SB 8 quart pan vs. 7 quart lowpro pan? [Re: mshred] #1613829
05/02/14 01:59 AM
05/02/14 01:59 AM
Az
Crizila Offline
Crizila  Offline
Az
Enough is not dropping oil pressure through the lights or on decel and keeping the oil temp in a safe operating range for the oil you are using. I would prefer to have a little more sloshing around in there ( even if it cost me a little HP ) rather than run out at 7K cause I pumped the oil level below the pick up. You run out of pressure at 7K you WILL hurt the motor. Then the question becomes - how much you hurt it.
Fastest 300
Re: Milodon SB 8 quart pan vs. 7 quart lowpro pan? [Re: Crizila] #1613830
05/02/14 04:23 AM
05/02/14 04:23 AM
SoCal
Brian Hafliger Offline
SoCal
Only way you'll ever pump the pan dry is if it's pumped into the heads! At any rpm, this is the only way that can happen.
Too much oil will get pulled up by the crank and airate the oil, super heat the oil around the crank, and eventually starve the pump with cavitation.
You really have to pour a pan and check them for how much they'll hold under the baffling, then add the proper amount back for the oil galleys and filter. Try pouring a 7Qt pan and see how much is actually held in the sump...you'll be amazed!!
Brian Hafliger
Re: Milodon SB 8 quart pan vs. 7 quart lowpro pan? [Re: Brian Hafliger] #1613831
05/02/14 11:07 AM
05/02/14 11:07 AM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
This is what I did with my 416.
Took the measurement from the bottom of the crank throws. Transfered this to my pan, filled the pan to the line and measured how much.
8 Litre and one litre for the rest.
This was with a Milodon pan.
Re: Milodon SB 8 quart pan vs. 7 quart lowpro pan? [Re: Brian Hafliger] #1613832
05/02/14 09:13 PM
05/02/14 09:13 PM
Az
Crizila Offline
Crizila  Offline
Az
I did that, including the engine angle as it sits in the car. With 7 qts, I was well under the tray and pan baffle. This was with a static engine and no oil in the filter, so running, the oil level clearance to the crank would be greater. I had no way of measuring that as I don't know how much a running small block holds above the crank. I won't even go in to the windage tray issue except that Milodon sells one to work with that 8 qt pan - and I am a believer in them. So, where is the oil going with all those giant wheelies I see on this sight???? Pump has to be sucking air for some period of time.
Fastest 300
Page 3 of 3 1 2 3
