remote oil filter #1613646
04/29/14 06:00 PM
04/29/14 06:00 PM
mississippi
bentwheel43 Offline OP
mississippi
Hi, I just got a new car it has a remote oil filter with 2 filters. I had a leak so I took it off to check the O-ring. When I put it back on I put it out of the motor to out on the filter by (mistake)and started the motor just 20 or 30 seconds to see if the leak stopped then turned it off. The motor had new oil call the man that sold me the car told me that it had to go back out of the motor to in on the filter so I switched it back my question is did I hurt any thing.
Section 8 Racing We are nuts about racing.
Re: remote oil filter [Re: bentwheel43] #1613647
04/29/14 06:04 PM
04/29/14 06:04 PM
sg66mopar Offline
sg66mopar  Offline
"Probably" didn't hurt anything, especially if the motor is not fresh. That said, might be time to pull the pan and a couple bearing caps.
Re: remote oil filter [Re: bentwheel43] #1613648
04/29/14 06:10 PM
04/29/14 06:10 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The outer side of the filter(OD of it) is ALWAYS the
inlet side... it has greater surface area to catch
more trash... like was said if its been a running
engine you didnt hurt anything... put the fittings
on right and run it... cut open the filter to check
it out
Re: remote oil filter [Re: sg66mopar] #1613649
04/29/14 06:11 PM
04/29/14 06:11 PM
mississippi
mississippi
The Motor has 20 1/8 passes.
Re: remote oil filter [Re: bentwheel43] #1613650
04/29/14 06:17 PM
04/29/14 06:17 PM
MR_P_BODY Offline
MR_P_BODY  Offline
It should be fine... just get the lines on right
and cut the filter open to check it out
Re: remote oil filter [Re: MR_P_BODY] #1613651
04/29/14 06:39 PM
04/29/14 06:39 PM
mississippi
mississippi
Thanks Mike
Re: remote oil filter [Re: bentwheel43] #1613652
04/29/14 06:49 PM
04/29/14 06:49 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thanks Mike
Good lookin ride... I built one of those for my brother
but it didnt have the hoover front end on it(thats
what he called them).. said it looked like a vacuum
cleaner.... I sorta liked it
Re: remote oil filter [Re: MR_P_BODY] #1613653
04/29/14 07:36 PM
04/29/14 07:36 PM
sg66mopar Offline
sg66mopar  Offline
Just don't get any air under it at 160.
