Page 5 of 13 1 2 3 4 5 6 7 12 13
Re: "Custom 33" [Re: Matt Erich] #1613551
01/04/15 04:00 PM
01/04/15 04:00 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
The website has finally been updated with new pictures showing the latest chassis improvements. www.custom33.com
lol
Damn near everything I bitched about with your old chassis is "fixed" in your new.
Might want to crib notes from here.
Don't be the exception.
Re: "Custom 33" [Re: Supercuda] #1613552
01/04/15 09:02 PM
01/04/15 09:02 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Thanks for the web sight link. Lots of good tech info.
Fuel system is almost complete. Aluminum 13 gal tank is from RCI. It will be a dead head system ( no return line - although the tank is bunged for one ). Small 3-4 psi electric pump will be located near the rear frame kick up to keep the line charged to a mechanical pump at the motor. Should eliminate any vapor lock issues that may arise.
Fastest 300
Re: "Custom 33" [Re: Crizila] #1613553
01/04/15 09:13 PM
01/04/15 09:13 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
tank
Fastest 300
Re: "Custom 33" [Re: Crizila] #1613554
01/04/15 09:13 PM
01/04/15 09:13 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Tank cover
Fastest 300
Re: "Custom 33" [Re: Supercuda] #1613555
01/04/15 11:28 PM
01/04/15 11:28 PM
IN
Matt Erich Offline
Matt Erich  Offline
IN
Thank you for the inspiration
lol
Owner of Custom33.com 1933 Plymouth Coupe and Roadster Kits
Re: "Custom 33" [Re: Matt Erich] #1613556
01/18/15 11:04 PM
01/18/15 11:04 PM
IN
Matt Erich Offline
Matt Erich  Offline
IN
Shop picture that shows half of the steel interior. We will add additional bracing later this week.
Re: "Custom 33" [Re: Matt Erich] #1613557
01/18/15 11:08 PM
01/18/15 11:08 PM
IN
Matt Erich Offline
Matt Erich  Offline
IN
2nd Picture
Re: "Custom 33" [Re: Matt Erich] #1613558
01/18/15 11:52 PM
01/18/15 11:52 PM
moparx Offline
moparx  Offline
what is the purpose of the oval holes on the outer perimeter of the floor plates ? if used for access to hide wiring, is there a box section below them, and what thickness[ga.] is it ?
Re: "Custom 33" [Re: moparx] #1613559
01/20/15 01:41 AM
01/20/15 01:41 AM
IN
Matt Erich Offline
Matt Erich  Offline
IN
The body is channeled so you have a valley under the holes. Many customers hide wires but the main purpose of the holes are to access the bolts that hold the fenders to the body.
Re: "Custom 33" [Re: Matt Erich] #1613560
01/20/15 09:10 PM
01/20/15 09:10 PM
IN
Matt Erich Offline
Matt Erich  Offline
IN
The plate is 1/4 inch thick. Sorry I overlooked that question.
Re: "Custom 33" [Re: Matt Erich] #1613561
01/22/15 04:04 PM
01/22/15 04:04 PM
IN
Matt Erich Offline
Matt Erich  Offline
IN
Some pictures of the cars being built in Australia
Re: "Custom 33" [Re: Matt Erich] #1613562
01/22/15 04:04 PM
01/22/15 04:04 PM
IN
Matt Erich Offline
Matt Erich  Offline
IN
Another
Re: "Custom 33" [Re: Matt Erich] #1613563
01/22/15 04:05 PM
01/22/15 04:05 PM
IN
Matt Erich Offline
Matt Erich  Offline
IN
another view
Re: "Custom 33" [Re: Matt Erich] #1613564
01/22/15 04:06 PM
01/22/15 04:06 PM
IN
Matt Erich Offline
Matt Erich  Offline
IN
Last
Re: "Custom 33" [Re: Matt Erich] #1613565
01/22/15 04:36 PM
01/22/15 04:36 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Is the additional bracing something you add to all the bodies, or is it a requirement for glass cars sent to Australia, or an extra expense customer request? Gene
Re: "Custom 33" [Re: poorboy] #1613566
01/22/15 09:04 PM
01/22/15 09:04 PM
IN
Matt Erich Offline
Matt Erich  Offline
IN
Everything that you see except the trunk steel structure is supplied by custom33. When we finished making a template for the trunk we will start offering the trunk also.
Re: "Custom 33" [Re: Matt Erich] #1613567
01/23/15 08:19 AM
01/23/15 08:19 AM
moparx Offline
moparx  Offline
it looks like the bracing is 1"x 16ga. tube ? or ?
Re: "Custom 33" [Re: moparx] #1613568
01/23/15 06:57 PM
01/23/15 06:57 PM
IN
Matt Erich Offline
Matt Erich  Offline
IN
Correct
Re: "Custom 33" [Re: Matt Erich] #1613569
01/27/15 08:35 PM
01/27/15 08:35 PM
Mopar Lane,Mississippi
67HEMI Offline
67HEMI  Offline
Would there be room for this and a Torqueflite if we left the hood off and put on a pair of zoomies?
I am seriously considering building a street rod or buying a rolling chassis to put this in.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction) '69 Chrysler 300 Convertible 375 HP 440 '71 Plymouth Duster 360 W/EFI (Wife's Ride) '12 Ram MegaCab Dually 6.7 Cummins
Re: "Custom 33" [Re: 67HEMI] #1613570
01/28/15 12:43 PM
01/28/15 12:43 PM
IN
Matt Erich Offline
Matt Erich  Offline
IN
Great talking to you about the potential build! If you order a car we will make the motor fit. That is the nice part about having the jig at the shop.
I would think you would have Mopar Magazines begging you for a cover picture of the car with that motor!
