Is my battery dead? #1613287
04/28/14 09:45 PM
04/28/14 09:45 PM
Detroit
Got2Gnow Offline OP
Got2Gnow  Offline OP
Detroit
Went out to start my Dart yesterday and got the dreaded "click". Tried to jump it with my Neon. Put the cables on it and turned over about half a revolution then "click". Let the Neon run for a while to let it "charge". Turned the key and "click".
Borrowed a 2A/6A/10A charger and connected it to the battery. Plugged it in and pressed the 2A charge button. The charger then automatically shut off "FAULT" after about 2 seconds.
Is it time for a new battery? Is it possible for a battery to be that dead that quick?
And yes all connections are clean and tight.
Re: Is my battery dead? [Re: Got2Gnow] #1613288
04/28/14 09:51 PM
04/28/14 09:51 PM
I'd slow charge it overnight (6A) & report back. but your saying it kicks the charger off pretty much immediately with a fault indication?
Re: Is my battery dead? [Re: RapidRobert] #1613289
04/28/14 09:54 PM
04/28/14 09:54 PM
okla.
O
okie Offline
okie  Offline
O
okla.
Sounds like it has shorted on the inside, I would say it is bad. Take it to O'Rielly's are some where they can check it.
Re: Is my battery dead? [Re: Got2Gnow] #1613290
04/28/14 09:59 PM
04/28/14 09:59 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
It sounds like dirty connections to me. You sure there clean and tight? If so...
Then the battery is junk. What's the volt meter say that you have hooked up to the battery for testing when you try to crank it?
Re: Is my battery dead? [Re: RapidRobert] #1613291
04/28/14 10:11 PM
04/28/14 10:11 PM
Detroit
Got2Gnow Offline OP
Got2Gnow  Offline OP
Detroit
Yes, the charger immediately shuts off and illuminates the "FAULT" LED.
Re: Is my battery dead? [Re: Challenger 1] #1613292
04/28/14 10:13 PM
04/28/14 10:13 PM
Detroit
Got2Gnow Offline OP
Got2Gnow  Offline OP
Detroit
Yes, the connections are clean and tight. Unfortunately, I have no meter to measure during crank.
Re: Is my battery dead? [Re: Got2Gnow] #1613293
04/29/14 03:12 AM
04/29/14 03:12 AM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Most battery chargers are unable to recharge a completely dead battery. The dead battery to the charger shows as no battery hooked to it and the charger refuses to try to charge. Check out Optima(there are others) whose chargers can deal with this.
You also may try hooking up a fully charged good battery in parallel using jumper cables to the failing battery(negative to negative and positive to positive) and let this set for a few hours. This will transfer energy from the good battery to the failed one. You then may find that your failed battery has regained its mojo and then your charger will happily charge it to full capacity. I would try this before considering it doomed
Re: Is my battery dead? [Re: Sxrxrnr] #1613294
04/29/14 10:36 AM
04/29/14 10:36 AM
Yeah it's all about the Mojo & I suspicioned that we were missing something here cuz an internally dead shorted batt is rare & hooking up the cables correctly is simple & I'm now also wondering how the batt went completely dead
Re: Is my battery dead? [Re: RapidRobert] #1613295
04/29/14 12:58 PM
04/29/14 12:58 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Disconnect the terminals and clean the posts, leave the wires off and slowly charge with a 1/2 amp charger for at least 24 hours. If it doesn't charge , its toast. If you don't have a 1/2 amp charger Harbor Freight has them on sale starting 5-01-14 for about 6 dollars and they work great. I use them on the race car during the week, my motor home, and tractor. Like I said leave the wires disconnected when a battery is "super dead"
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Is my battery dead? [Re: pittsburghracer] #1613296
04/29/14 01:02 PM
04/29/14 01:02 PM
PA.
"Little"John
"Little"John
PA.
To add to the above post I bought my Mothers 2003 chevy malibue when she passed away in 2009 and the stock battery was totally dead twice from my sister leaving the glove box open. I brought it back both times and I am still using the 11 year old battery.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Is my battery dead? [Re: RapidRobert] #1613297
04/29/14 01:04 PM
04/29/14 01:04 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Thats what I thought too, but I had one about two years ago and then a buddy a few months later. If it was internally shorted I don't think you'd get the click or anything though. Mine couldn't even turn the dome light on with jumper cables hooked up. It was fine the week before when I took it out.
I agree with the above, clean your connections and check your engine to chassis ground and battery to engine ground.
Re: Is my battery dead? [Re: GTX MATT] #1613298
04/29/14 01:28 PM
04/29/14 01:28 PM
3rd rock
K
kloyiod Offline
kloyiod  Offline
K
3rd rock
2 questions. How old is this battery, and how long did it sit idle without any use? The average lifespan of a battery is 4 years, they may live to 8-9 years but your living on borrowed time.
Re: Is my battery dead? [Re: Sxrxrnr] #1613299
04/29/14 03:13 PM
04/29/14 03:13 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Check voltage on your battery. If under 10 1/2 volts, it will not accept a charge from most consumer type chargers. If so again,,,hook a fully charged battery in parallel as outlined before all should be well. If your dead battery should get excessively warm, this likely suggests an internal short and battery is probably beyond recovery.
Always wear proper eye protection when dealing with auto batteries,,,,a blown up battery is quite a sight to behold.
