AF Ratio #1613219
04/28/14 04:15 PM
04/28/14 04:15 PM
Sweden
Mopar Guy Offline OP
Sweden
What numbers should i look for on the AF Ratio when i jet my carbs ?
Re: AF Ratio [Re: Mopar Guy] #1613220
04/28/14 04:21 PM
04/28/14 04:21 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
What use is the car going to be seeing?
Street cruising?
Wide open throttle drag racing?
Road racing?
Re: AF Ratio [Re: Kern Dog] #1613221
04/28/14 04:24 PM
04/28/14 04:24 PM
Sweden
Sweden
Mostly on the street for the highway but of corse i like to open up some time when a BMW turns up Engine is a 505 RB stroker whit a 6-Pack !
Re: AF Ratio [Re: Mopar Guy] #1613222
04/28/14 04:52 PM
04/28/14 04:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The only time I use the A/F meter is to set the cruise
ratio... set the idle so it idles the best it can,
set the WOT to the best MPH at the track... set the
cruise at about 14.5-15.5 at a level no load or very
minor load.... once you get it all set THEN take a
idle and WOT reading so you can get back to it fairly
easy
