Fender Tag Code N4I?? #1613200
04/28/14 02:58 PM
04/28/14 02:58 PM
Slidell, LA
Plum440 Offline OP
Plum440  Offline OP
Slidell, LA
Can someone please tell me what this code is? I can't find any information on the internet.... Thank you!
70 Challenger, 440, 4-speed, pLuM cRaZy
71 VW Super Beetle Convertible, Lemon Yellow
A couple of Jeeps…
Re: Fender Tag Code N4I?? [Re: Plum440] #1613201
04/28/14 03:02 PM
04/28/14 03:02 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
N41= dual exhaust.
Re: Fender Tag Code N4I?? [Re: mccannix] #1613202
04/28/14 07:56 PM
04/28/14 07:56 PM
Slidell, LA
Plum440 Offline OP
Plum440  Offline OP
Slidell, LA
Man, it sure does look like an I and not a 1. But that could be why I'm not finding it...
Thanks!
A couple of Jeeps…
Re: Fender Tag Code N4I?? [Re: Plum440] #1613203
04/28/14 08:02 PM
04/28/14 08:02 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
Thanks!
Does look like an "I".....also clearly looks like a repop tag. Maybe they made a mistake when it was remade? Should be N41.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Fender Tag Code N4I?? [Re: 70gtx440dana] #1613204
04/28/14 09:59 PM
04/28/14 09:59 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Agree
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: Fender Tag Code N4I?? [Re: 69CoronetRT] #1613205
04/29/14 09:29 AM
04/29/14 09:29 AM
Slidell, LA
Plum440 Offline OP
Plum440  Offline OP
Slidell, LA
Thanks guys! With the car having its original broadcast sheet, the repop tag doesn't bother me. I thought the same too so it's good to see this feedback.
A couple of Jeeps…
Re: Fender Tag Code N4I?? [Re: Plum440] #1613206
04/29/14 11:29 AM
04/29/14 11:29 AM
Ball Ground GA
TrueTripleX Offline
TrueTripleX  Offline
Ball Ground GA
Check your build sheet to be sure it shows the N41 coded. You should have dual exhaust without chrome tips if the car is to be correct. Chrome tips were coded N42
Re: Fender Tag Code N4I?? [Re: TrueTripleX] #1613207
04/29/14 04:19 PM
04/29/14 04:19 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
As noted on that tag ...
