01 jeep 4.7 oil pressure #161295
12/04/08 09:31 PM
12/04/08 09:31 PM
MD
HEMI472 Offline OP
HEMI472  Offline OP
MD
i have a 01 jeep with a 4.7 and the oil pressure keeps going frome 20 to 50 psi.i think the sending unit is bad can someone tell me where it is? thanks ed
Re: 01 jeep 4.7 oil pressure [Re: HEMI472] #161296
12/04/08 11:30 PM
12/04/08 11:30 PM
Mission BC
10sec440 Offline
10sec440  Offline
Mission BC
Its on the front, drivers side right by the oil filter.Chances are its not the sending unit although its a good idea to rule that out first. Usually a fluctuation like that is caused by gritty carbon-like stuff in the oil pan. The good news is if it doesn't go on for a long time you can clean the pan out and it doesn't usually damage anything.
Re: 01 jeep 4.7 oil pressure [Re: 10sec440] #161297
12/05/08 01:21 AM
12/05/08 01:21 AM
MD
HEMI472 Offline OP
HEMI472  Offline OP
MD
well i bought it new and have all ways changed the oil every 2000 miles using penzoil 5 w 30 in the winter and 10w 30 in the summer and the oil always looks good.can i get the pan off with the motor in the jeep? thanks ed
