55 gallon e-85/98 #1612873
04/27/14 10:19 PM
04/27/14 10:19 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
What or the going prices per drum?...............
Re: 55 gallon e-85/98 [Re: racerx] #1612874
04/27/14 10:24 PM
04/27/14 10:24 PM
Dayton, OH
1980volare Offline
My man card has just been revoked.
1980volare  Offline
Dayton, OH
3.16/ gal at the pump for e85 here right now. Not sure on drums.
Re: 55 gallon e-85/98 [Re: racerx] #1612875
04/28/14 09:01 AM
04/28/14 09:01 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I sell Sunoco race fuels, I had a customer ask about E85R from Sunoco. It is $454.54 a drum.
Re: 55 gallon e-85/98 [Re: Challenger 1] #1612876
04/28/14 09:26 AM
04/28/14 09:26 AM
Indy
FlyFish Offline
FlyFish  Offline
Indy
Ouch! Yeah, just a little over 3 bucks a gallon at the pump here too (that would be about $170 for 55 gallons).
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: 55 gallon e-85/98 [Re: FlyFish] #1612877
04/28/14 08:03 PM
04/28/14 08:03 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
I paid 3.69 a gallon here right before Easter and it was e-70 (winter blend)
Re: 55 gallon e-85/98 [Re: racerx] #1612878
04/28/14 08:10 PM
04/28/14 08:10 PM
tboomer Offline
tboomer  Offline
I think it is 2.79 at the pump here. I will look tomorrow.
Re: 55 gallon e-85/98 [Re: racerx] #1612879
04/28/14 08:52 PM
04/28/14 08:52 PM
Q
Quicktree Offline
Quicktree  Offline
Q
ok, multiply that times 55 and you will have the price for a drum
Re: 55 gallon e-85/98 [Re: tboomer] #1612880
04/29/14 12:39 PM
04/29/14 12:39 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
Ted how are you doing?
If you go in the station, ask if they have "drop sheets" for last delivery of E-85. That way we know what percentage the fuel is.
Thanks, Don
Re: 55 gallon e-85/98 [Re: cudadon] #1612881
04/29/14 12:41 PM
04/29/14 12:41 PM
Cincinnati, Ohio
Cincinnati, Ohio
Thanks, Don
You mean bill of lading.
Re: 55 gallon e-85/98 [Re: Challenger 1] #1612882
04/29/14 12:49 PM
04/29/14 12:49 PM
Renton Washington
Triple Threat Offline
Renton Washington
E85 is more expensive out here in the northwest because there isn't a lot of demand for it, and it has to be trucked out here. I paid $4.15 last week and bought 72 gallons ($300).
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: 55 gallon e-85/98 [Re: Challenger 1] #1612883
04/29/14 12:50 PM
04/29/14 12:50 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thanks, Don
The station people will know it as the drop sheets..
to them its just paper work... I always asked for
the drop sheets and they knew what I meant
Re: 55 gallon e-85/98 [Re: MR_P_BODY] #1612884
04/29/14 01:49 PM
04/29/14 01:49 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I saw it for $2.89 here last week.
I have never been able to get anyone to show me the drop sheets. Most of the time I just get a blank look from the guy making minimum wage behind the counter.
I just bring an empty water bottle and put a little in it before I fill up. Then I check it with my quick fuel tester before I fill up with any significant quantity.
I think there is a lot of bad info out there that E85 will vary a lot. I've checked quite a bit of it, and have never seen it go below 83% in any reasonable weather you'd drive your car in.
Re: 55 gallon e-85/98 [Re: dizuster] #1612885
04/29/14 02:05 PM
04/29/14 02:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Scott.. I was buying it from Myiers at 26 and VanDyke
and every time I checked the summer fuel it was 85%
to 86%... I would ask a customer if I could get a
little bit while they were filling and then show them
what they were getting... I never had a problem from
anyone about getting a little bit.. most would hang
around just to see what it was.. those employees knew
what I was asking for when I asked for the drop sheets..
seems like its getting more common now days for people
to ask for the drop sheets... I gather a lot more
guys are racing with it than some years back when
I started using it
Re: 55 gallon e-85/98 [Re: MR_P_BODY] #1612886
04/29/14 02:23 PM
04/29/14 02:23 PM
Indy
496 A-body Offline
496 A-body  Offline
Indy
I started using it
What cranking pressure is 85% ethanol safe to?
Re: 55 gallon e-85/98 [Re: 496 A-body] #1612887
04/29/14 02:50 PM
04/29/14 02:50 PM
MR_P_BODY Offline
MR_P_BODY  Offline
No clue... its well above mine
Re: 55 gallon e-85/98 [Re: MR_P_BODY] #1612888
04/29/14 07:08 PM
04/29/14 07:08 PM
San Antonio,TX
440W8 Duster Offline
San Antonio,TX
My last 55 gal drum(E98) I purchased in Aug'13 was $165.00.
70 Duster W8 motor.
1.29 60ft 5.79 1/8 at 120 mph
glide with 1.80 gear
@3170 lbs.
Re: 55 gallon e-85/98 [Re: 440W8 Duster] #1612889
04/29/14 10:54 PM
04/29/14 10:54 PM
Indy
496 A-body Offline
496 A-body  Offline
Indy
Nice! What state was this purchase made in?
Re: 55 gallon e-85/98 [Re: 496 A-body] #1612890
04/29/14 11:06 PM
04/29/14 11:06 PM
San Antonio,TX
San Antonio,TX
North Dakota.
70 Duster W8 motor.
@3170 lbs.
Re: 55 gallon e-85/98 [Re: 440W8 Duster] #1612891
04/29/14 11:45 PM
04/29/14 11:45 PM
Dandridge TN
Dabee Online content
Dabee  Online Content
Dandridge TN
All we can get at the pump here in Tennessee is E70. I've been mixing E98 with it to make E85. I only have enough E98 for a couple more trips to the track, so I'm thinking about rejetting the carb for E70 and see how that works. Mike, what are your thoughts on running on E70?
Re: 55 gallon e-85/98 [Re: Dabee] #1612892
04/30/14 12:04 AM
04/30/14 12:04 AM
MR_P_BODY Offline
MR_P_BODY  Offline
If your compression will handle it then just change
your settings to adjust to E-70
