Re: Any advice??
[Re: moparman76440]
#1612824
04/27/14 07:13 PM
04/27/14 07:13 PM
Challenger 1
Cincinnati, Ohio
Hi everyone, i'm Mark and im new to moparts.com and I need some advice or suggestions. I have a 1976 Dodge D-100 stepside 2 wheel drive. It has a 440 out of a '76 Winnebago motorhome in it. The tranny is of course a 727 TorqueFlight. It has an 8.75 posi rear with 4.10 gears. It has an Edelbrock 600 cfm 4 barrel carb sitting on a Weiand dual plane intake manifold. It has Hedman headers and currently is running dual side pipes with Series 10 Flowmasters. I love the nasty sound of the mufflers and the mild Street Pounder cam it has but it doesnt run like it should. From take off up until 2500-2750 rpms it has misses and breaks up alot but after 2750-3000 it runs decent but not where it should be. It idles really good except for a noticable miss or two here and there. I was just wondering if ya'll had any advice or suggestions for me as to what to look for and where my problem might be? And any suggestions for the best flowing exhaust for this hog would be greatly appreciated! Thanks a ton!!
Welcome...
First it sounds like you need a basic tune up to begin with. That is assuming the motor is sound inside. What's the plugs look like?
Then second for performance you need a bigger carburetor for a 440. That will wake up the top end. Is your 600 a 1405 or 1406?
You have plenty of exhaust capacity at this point with 600 carb. Yea the flowmasters are loud and I don't like them. There way better/quieter mufflers out there IMO.
Re: Any advice??
[Re: Challenger 1]
#1612825
04/27/14 08:21 PM
04/27/14 08:21 PM
Posts: 8,670 Buford, GA
I_bleed_MOPAR
Buford, GA
with both of the above. Stock distributor? Try disconnecting the vacuum advance. Secondary air valve on carb may be opening too soon? Carb size is small even for a stock 440. Do you have true side pipes or a side-exit exhaust? Most side pipes I've seen have mufflers inside. Sounds like a nice truck. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
Re: Any advice??
[Re: moparman76440]
#1612829
04/27/14 11:22 PM
04/27/14 11:22 PM
Challenger 1
Cincinnati, Ohio
Last summer I put new E3 plugs in it and new plug wires along with new cap and rotor and fresh oil and filter. I run synthetic oil with a Wix filter. The motor was apart and freshened up in 06, however it hasnt been inspected so it hasnt see ALOT of pavement except the test runs around the block that i take lol. Yes it has a stock distributor, the one that was in the motor when it was in the motorhome yet. A local engine builder did the work on it and put a mild street pounder cam in it. It shifts fine. I will try the vacuum advance thing and see how it works. And when I first got the motor back I was running a 750 Holley carb on it and we messed with the air/fuel mixture many many times and couldnt get it close. It ran worse then with the 750 carb than it does with the 600. The Edelbrock 600 is a 1406 with the electric choke. Thanks again guys!
Time to pull the plugs and see what they look like. My suggestion is to put regular plugs in it, I bet yours are starting to foul? E3
The 1406 carb is really lean on a small block engine. I bet it lean on a big block engine also.
Now lean shouldn't cause it misfire at idle, but it could under load. That's why I think you need to look at your plugs again. They tell the story, must look at them often while tuning it until you get it figured out. Good luck.
Re: Any advice??
[Re: Challenger 1]
#1612831
04/28/14 12:20 AM
04/28/14 12:20 AM
Posts: 3,344 Central TX
roe
Central TX
I agree with the point about the carb. My 1406 was way lean for my MILD 360. I cant imagine how lean it would be on a 440. Do yourself a favor, get a calibration kit for the carb, and calibrate it as a 1405 (manual choke version of same carb). Those are setup much richer as a performance carb, instead of economy setup they give the 1406. For example, 2 steps rich in cruise and power mode on the 1406 calibration chart was still 1 step lean on the 1405 chart. So use the 1405 chart to calibrate your 1406 if you stay with it. I did a bunch of reading online for tuning that carb and then I dove right in. It let me learn a lot about carb tuning. But if you're looking for an upgrade to make that 440 run, I think you're going to need a bigger/better carb for your combo. roe
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
Re: Any advice??
[Re: roe]
#1612833
04/28/14 12:31 AM
04/28/14 12:31 AM
Posts: 7 Mifflinburg, PA
moparman76440
Mifflinburg, PA
Oh damn I didnt know the manual choke 600's were set up more for performance or I would have gone with that setup. I might have to get that calibration kit and see what that does. Edelbrock, Holley or Demon guys...I've messed with Holleys and Edelbrocks but not with Demons and for me I think Holleys are harder to tune but then Ive got buddies who swear by Holley and say Edelbrocks are junk so i dont know, maybe get a 800 Demon and say the hell with it! LOL Thanks again! And if thats your car then Awesome ride man!! I love the Satellites and RoadRunners, favorite body styles. Along with the 68 and 69 Barracudas.
Re: Any advice??
[Re: moparman76440]
#1612835
04/28/14 12:54 AM
04/28/14 12:54 AM
roe
Central TX
Yeah, I was shocked too when I found out how big of a difference it is between the calibration on the 2 carbs. I have no experience with the demon or holley carbs, but I hear great things on this board about the demon carbs. I think you can calibrate that carb to perform fairly well with your motor, but there are guys on this board who have been wrenching longer than I've been alive , so I would say to take their advice over mine. Thanks for the compliment on the car. I have a 360 magnum based 408 going into it now, built by another member here. Putting a Holley 3310, 750cfm vac secondary, on it.
Re: Any advice??
[Re: moparman76440]
#1612836
04/28/14 01:39 AM
04/28/14 01:39 AM
Posts: 1,238 Nevada
dezduster
Nevada
Stock distributor that is likely why your engine is not up to par. A stock RV distributor would be way slow to let timing advance!! You have a deeply geared and light by comparison truck. I think your timing should be all in by 2600 to 3200 RPM maybe earlier. I am betting its not all in until 4000 RPM with those stock RV springs in your distributor.
Re: Any advice??
[Re: dezduster]
#1612837
04/28/14 12:05 PM
04/28/14 12:05 PM
Posts: 516 ND
dodgedon
ND
I would wonder about the ignition slso... I'm not sure you can run that 4 prong ballast with the chrome box? High performance units use a single ballast resistor and only four wires from the control unit. Production units typically used a dual ballast resistor and five wires from the control unit. The proper ballast is determined by the coil, and there are at least four differeent single ballast resistors. I would also agree with above about the stock distributor being slow for your application.
67 Charger 383 auto 75 Dodge CNT 800 CAT Diesel 2012 Ram Crew cab 5.7 4x4
Re: Any advice??
[Re: moparman76440]
#1612840
04/29/14 03:36 AM
04/29/14 03:36 AM
Posts: 3,310 Walnut Creek, CA
blown340
Walnut Creek, CA
What is your timing set at? The issues you reference sound way more timing related than anything else.
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah
71 valiant scamp 318/A833OD/AC/PS
00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process
73 W200 Power wagon, PTO winch, 4 spd
Re: Any advice??
[Re: blown340]
#1612841
04/29/14 07:32 AM
04/29/14 07:32 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Dont get that kit from Ebag. Ger a remaned dist new ECU and ballast resistor from your favorite local parts house. Mopar Perf has the harness. You will be money ahead. Todays orange boxs are junk nowdays.
I am truckless..
