Well I can set the timing on it and then when I take it for a ride and come back the timing is off. That's why I think the distributor is shot all together? I tried unhooking the vacuum advance and nothing changes. I would like to run this truck without the ballast resistor and orange box but I'm not sure if this is possible and if it is possible what all would I need to get to do that?
