Re: Vertical movement in distributor??
[Re: hemi-itis]
#1612674
04/27/14 02:04 PM
04/27/14 02:04 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Most have slop in them.. as to a 1/4" that is a bit much... time for a collar on the shaft to keep the timing tight(as the intermediate shaft moves up and down the timing changes)
[Re: Quicktree]
#1612676
04/27/14 03:08 PM
04/27/14 03:08 PM
MR_P_BODY
what kind of dist is that?
That looks like the old tach drive thats been changed over to electronic or it was electronic and tach drive
[Re: MR_P_BODY]
#1612677
04/27/14 05:04 PM
04/27/14 05:04 PM
Quicktree
thats what I was thinking and although they ran fine I thought with that big Hemi he would have moved into the 21st century
and I figured his fried Chris would help him out
[Re: MR_P_BODY]
#1612678
04/27/14 05:05 PM
04/27/14 05:05 PM
Posts: 12,589 Great Neck,LI,new york
hemi-itis
Mr p would be right,old MP electronic with tach drive. Think it's time for a Firecore distributor & wires
[Re: hemi-itis]
#1612681
04/27/14 06:11 PM
04/27/14 06:11 PM
MR_P_BODY
Think that might be causing a high rpm miss Will still be a few weeks before I can do any testing
If the timing is jumping around then yes it could cause a miss... with a 1/4" of vertical movement the intermediate shaft would be turning a FAIR amount and it would be hard to say what the timing is at any given point.. yeah it might be time to get a new dist unless you feel like rebuilding that one... but if you dont use the tach drive why bother(and I dont see a cable hooked up to it)
[Re: MR_P_BODY]
#1612682
04/27/14 06:36 PM
04/27/14 06:36 PM
hemi-itis
Have not used the tach MANY years Time to replace and I think Rich has a great product It might just be a lean pop,but until I get this rotater cuff back in shape,I can't even get in & out of the car
[Re: hemi-itis]
#1612683
04/27/14 07:10 PM
04/27/14 07:10 PM
MR_P_BODY
Sucks getting old... I had both shoulders rebuilt and had 1 done again... yep it sucks getting old
[Re: max_maniac]
#1612687
04/28/14 10:07 PM
04/28/14 10:07 PM
hemi-itis
I am getting rid of my "tall mechanical distributor" and installing exactly what you have
Russ
Russ,your going back to a MOPAR unit?,,,,Why??,,,,,
