Who makes correct inside window wipes for AARs? #1612523
04/26/14 10:48 PM
04/26/14 10:48 PM
mopar346 Offline OP
Let me tell ya about fat chicks!
mopar346  Offline OP
I have a set that I used the outside ones on the car and I am getting ready to install the door panels and the ones in the set for the inside rivot to the door panel where as the originals kinda slip on or clip on. Does anyone make the original style ones or am I stuff with the rivot style?
Thanks in advance, Kevin
Careful, your character's showing!
Re: Who makes correct inside window wipes for AARs? [Re: mopar346] #1612524
04/27/14 10:49 AM
04/27/14 10:49 AM
SE Pa.
LimeliteAero Offline
SE Pa.
These are the best available, youll probably use them to replace what you already used on the outsides once you see the difference.
http://www.restorationspecialties.com/Products.html
Re: Who makes correct inside window wipes for AARs? [Re: LimeliteAero] #1612525
04/27/14 11:57 AM
04/27/14 11:57 AM
JERSEY
RJS Offline
RJS  Offline
JERSEY
The TopCat brand is the way to go. Contact Randy (DIXIE) on this board.
Ron
Re: Who makes correct inside window wipes for AARs? [Re: RJS] #1612526
04/27/14 12:01 PM
04/27/14 12:01 PM
mopar346 Offline OP
mopar346  Offline OP
Thanks guys, I went to the site and downloaded the catelog but there are no illistrations, how do they attach? Is it the same clip on still at the factory or do they rivot on as well?
Re: Who makes correct inside window wipes for AARs? [Re: mopar346] #1612527
04/27/14 01:34 PM
04/27/14 01:34 PM
Ball Ground, Georgia
Dixie Offline
Dixie  Offline
The Top Cat Brand inside's snap on just like the originals. My concern based on your post is that the outers you have are incorrect as well. If it has a rubber lip that rides against your glass, it's wrong. It should be a felt lined sweeper in a v or u shaped channel.
Why is that a problem? Because when you wash the car or if it gets caught in the rain, that rubber lip will let water inside your doors. Our channeled outer felt lets the water drain like it should on the outside.
Here's a link to our felts: http://www.dixierestorationparts.com/product.cfm?pi=407E7EAB-EF81-FC33-20839983E174EB6E
If we can help, please let us know.
Thanks,
Randy
Dixie Restoration Parts
Phone -(770) 975-9898
Phone Hours: M-F 10am-5pm EST
website: www.dixierestorationparts.com
email: mail@dixierestorationparts.com
Veteran owned small business
The Best Parts at a Fair Price.
Re: Who makes correct inside window wipes for AARs? [Re: Dixie] #1612528
04/27/14 08:36 PM
04/27/14 08:36 PM
mopar346 Offline OP
mopar346  Offline OP
Thank you, you are correct the outside wipes have the rubber lip. I was thinking of driving up but Ball Ground is a little too far for an afternoon run. I also need the clips that go on the inside of the door panels at the top if you have those. I'll give you a call sometime tomorrow.
Thanks again, Kevin
Re: Who makes correct inside window wipes for AARs? [Re: mopar346] #1612529
04/27/14 09:20 PM
04/27/14 09:20 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Randy I need to order for my 72 Satellite Sebring. how do I know if I have early or late? Where is that measurement taken from?
Ron Sannino
71-72 Plymouth B body window felts- early-longer- 11 1/2 71-72 Plymouth B body window felts- early-longer- 11 1/2
Was: $165.00
Now: $150.00 - Qty:
71-72 Plymouth B late- window felts- shorter- 10 3/4 71-72 Plymouth B late- window felts- shorter- 10 3/4
$165.00 - Qty:
Re: Who makes correct inside window wipes for AARs? [Re: RJS] #1612530
04/30/14 12:49 AM
04/30/14 12:49 AM
Dixie Offline
Dixie  Offline
Ron Sannino
Was: $165.00
Now: $150.00 - Qty:
$165.00 - Qty:
If you look at the detailed description once you click on the product, it’ll state that it’s measured up the sail panel:
71-72 Plymouth B body window felts- early-longer- inner curved felt that goes up the sail panel is 11 1/2" long.
71-72 Plymouth B late- window felts- rear inner felt that goes up sail panel is shorter- 10 3/4"
Check your car out and let me know if that makes sense.
Thanks!
Randy
