1050 Dominator questions........ #1612374
04/26/14 04:47 PM
04/26/14 04:47 PM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
I upgraded my fuel system a couple weeks ago. I left the 950 carb on it and went to T&T week before last. It ran well,I drove it to track and back home. I made 4 passes it did not hook on the firs 2 at all. They finally sprayed the track and the next 2 passes it dead hooked and ran 2 6.30's, so the fuel system seems okay. I put my 1050 dom. on it Thurs. and it will not run unless you constantly pump the gas. I took the front metering block and bowl off and blowed with compressed air through all the holes in the block.I did not find any trash in it nowhere.I put it back together and it still will not run. The fuel is at the bottom of the sight plug. Can anybody tell me what I can do next? Thanks for any help.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: 1050 Dominator questions........ [Re: D-50] #1612375
04/26/14 04:56 PM
04/26/14 04:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
How are the mixture screws adjusted .. that is the idle
part of it... make sure the blades arent open to far
Re: 1050 Dominator questions........ [Re: MR_P_BODY] #1612376
04/26/14 05:00 PM
04/26/14 05:00 PM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
They were out 2 turns and I tried them at 1 1/2. Still no difference.
Re: 1050 Dominator questions........ [Re: D-50] #1612377
04/26/14 05:04 PM
04/26/14 05:04 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
What size are the idle air bleeds?
Re: 1050 Dominator questions........ [Re: D-50] #1612378
04/26/14 05:05 PM
04/26/14 05:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Make sure the blades arent opened to far... if they
are you wont be on the idle circuit and the mixture
screws wont react
Re: 1050 Dominator questions........ [Re: rickraw] #1612379
04/26/14 05:12 PM
04/26/14 05:12 PM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
I have no idea.I do not know how to check.
Re: 1050 Dominator questions........ [Re: D-50] #1612380
04/26/14 05:20 PM
04/26/14 05:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Pull the carb off.. flip it over and look at the transfer
slot.. it should look like a square hole when set
right..thats the narrow slot thats vertical in the
center of the bores on the opening side of the blades
Re: 1050 Dominator questions........ [Re: D-50] #1612381
04/26/14 05:20 PM
04/26/14 05:20 PM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
Mr. P are you talking about the front throttle blades? I went outside and turned the idle screw down some and it did not change. It will not even stay running after it starts if you hold the throttle part of the way down.
Re: 1050 Dominator questions........ [Re: D-50] #1612382
04/26/14 05:24 PM
04/26/14 05:24 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Make sure the rear blades arent open to far either..
a 1050 is basically 2 2 bbl carbs... you have mixture
screws on front and back.. if the rear blades are
open too much that side wont work right and be a major
vac leak
Re: 1050 Dominator questions........ [Re: D-50] #1612383
04/26/14 06:49 PM
04/26/14 06:49 PM
Central New York
slippery440 Offline
Crybaby440
slippery440  Offline
Crybaby440
Central New York
Make sure you use Dominator fuel bowl and metering block gaskets. There are extra holes.
If the MODS did their job I would not be hitting the notify MOD button. LOL
Re: 1050 Dominator questions........ [Re: MR_P_BODY] #1612384
04/26/14 08:48 PM
04/26/14 08:48 PM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
I took the carb off and looked and there was no transfer slot showing at all on the back. Do I set the slots square on the back then put it back on and see if that helps?
Re: 1050 Dominator questions........ [Re: D-50] #1612385
04/26/14 09:00 PM
04/26/14 09:00 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Set them squared up and put it back on.. try the mixture
screws at 1 1/4 to 1 1/2 turns out then adjust from there
Re: 1050 Dominator questions........ [Re: MR_P_BODY] #1612386
04/26/14 10:14 PM
04/26/14 10:14 PM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
I set the transfer slots square and set the idle mixture at 1 1/4 out. It cranks right up but will not run under about 3500 rpm unless you pump the gas.
Re: 1050 Dominator questions........ [Re: D-50] #1612387
04/26/14 10:19 PM
04/26/14 10:19 PM
PA
ajcasini Offline
ajcasini  Offline
PA
You have an idle circuit issue. I am assuming this is a 3 circuit carb. If you used a set if 2 circuit gaskets it will block off the idle feeds, etc. make sure that the gasket has 4 holes at the top on each side. One big and three little.
Re: 1050 Dominator questions........ [Re: ajcasini] #1612388
04/26/14 11:27 PM
04/26/14 11:27 PM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
It says 6980 3 on the metering blocks.
Re: 1050 Dominator questions........ [Re: ajcasini] #1612389
04/26/14 11:41 PM
04/26/14 11:41 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I never thought about the wrong gaskets being on it
Re: 1050 Dominator questions........ [Re: MR_P_BODY] #1612390
04/26/14 11:47 PM
04/26/14 11:47 PM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
I will check that.
Re: 1050 Dominator questions........ [Re: MR_P_BODY] #1612391
04/27/14 12:52 PM
04/27/14 12:52 PM
Central New York
slippery440 Offline
Crybaby440
slippery440  Offline
Crybaby440
Central New York
Gee I thought that I said that about 5 post before AJs
Re: 1050 Dominator questions........ [Re: slippery440] #1612392
04/27/14 02:00 PM
04/27/14 02:00 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Well thats good for you... I just didnt see it...
so if they are wrong then that makes you the hero
of the day
Re: 1050 Dominator questions........ [Re: MR_P_BODY] #1612393
04/27/14 03:32 PM
04/27/14 03:32 PM
Central New York
slippery440 Offline
Crybaby440
slippery440  Offline
Crybaby440
Central New York
No hero just been there done that!!
