Re: I hate oil leaks, RB engine
[Re: Moparnut426]
#1611946
04/25/14 06:25 PM
04/25/14 06:25 PM
Posts: 10,015 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Chuck over at Lofgren auto specialtys just showed me a new one piece seal that you have to lower the crank a bit, then cut to slide it into the channel, then seal the cut with RTV. He said they are about $90, but a lot of guys pay more to fix the issue.
[Re: gregsdart]
#1611947
04/25/14 07:25 PM
04/25/14 07:25 PM
Posts: 9,871 MI, usa
dvw
MI, usa
I have always run the stock seal retainer. I recently worked on a freinds new 440 with a leak. He had bought a "bilet" retainer. It still leaked. I installed it to the block and measured it up. The bolts didn't even center it in the block register.It was off .100". I had him order a new seal from Greg at superformanceproducts@yahoo.com Installed it in the factory retainer, problem solved. I've never had a rear main leak on any of my small or big blocks. Doug
[Re: dirty magnum]
#1611950
04/26/14 11:12 AM
04/26/14 11:12 AM
Posts: 3,325 Truckville, the capital of NY
85_Ram_4speed
I have done a half dozen big block builds (all differnt blocks/cranks), always used the stock retainer. Never had or heard of any leaks, some have several thousand miles on them--that's using a felpro seal too. I always put the block surface of a retainer just a touch on the belt sander to even it square---a file could do the trick too, use anerobic sealer between the retainer and block, and squeeze grey RTV in the side seals and I have used those little pipe cleaner thingys. I also offset the seal slightly with a dab of rtv on the ends. Works for me.
I will be looking into the superformance seal for the next build though, I believe it should be a good product from what I have heard.
Outcast Dodge guy.
