alignment specs? #1611455
04/24/14 11:42 AM
04/24/14 11:42 AM
MN
ryangtogtx Offline OP
MN
Looking for alignment specs for a cuda with a 340 and radial tires. Any help would be great. Thanks.
Re: alignment specs? [Re: ryangtogtx] #1611456
04/24/14 11:50 AM
04/24/14 11:50 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I run as much positive caster as I can get.Usually you need the Moog offset bushing in upper arms to get it positive.they install opposite of the instructions though.About 1/2 camber and about 1/16 toe.The factory specs arent for radials.Rocky
Chrysler Firepower
Re: alignment specs? [Re: ryangtogtx] #1611457
04/24/14 11:51 AM
04/24/14 11:51 AM
Georgia
Steve Bryant Offline
Georgia
My understanding is that the original specs were not designed for radial tires and so I use a SLIGHTLY more aggressive alignment for my driver.
Original:
.5 degree positive camber - .75 degree positive caster - 1/8 " toe-in
What I use:
.25 negative camber - 1.5 degree positive caster and 1/16 to 1/8" toe-in
Here is a good link:
http://www.allpar.com/history/photos/alignment/alignment-specifications.gif
Re: alignment specs? [Re: Steve Bryant] #1611458
04/24/14 12:02 PM
04/24/14 12:02 PM
What I use:
That sounds good & I would install the Moog offset UCA bushings with the arrow to the inside on the rear bushing on each side to get additional positive caster
