Manual Valve Body for a Daily Driver #161116
12/04/08 02:45 PM
12/04/08 02:45 PM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
Every manual valve body has something saying RACE ONLY or NOT RECCOMENDED FOR STREET USE. Why is this, just because of the harshness of the shifts or what?
I have my eye on this one
http://cgi.ebay.com/ebaymotors/MOPAR-Tor...eQ5fCarQ5fParts
I already shift my 904 manually because I dont like the shift points and the 904 kickdown just wont adjust to where I need it to be, shifting it is not a problem as I like to shift it myself (haha I really wanted a 4 speed!). Im swapping to a 727 and dont have a kickdown for it, this wont cost that much more, and if I didnt do this Id be installing a shift kit for hard shifts so this will probably cost less than the kickdown and shiftkit would together.
Opinions?
Re: Manual Valve Body for a Daily Driver [Re: GTX MATT] #161117
12/04/08 02:52 PM
12/04/08 02:52 PM
lawyers.
if you got into an accident because you didnt shift right or it made you go sideways when it hits second, someone might sue them
Re: Manual Valve Body for a Daily Driver #161118
12/04/08 03:03 PM
12/04/08 03:03 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
alot of racers drive on the street with manual valve bodies...
as noted above..just a disclaimer to protect the manufacturer...
one thing with a no low band apply valve body as this is...if you are in 1st gear and coasting..do not floor it...
Tony
70 AARCuda Vitamin C
Re: Manual Valve Body for a Daily Driver [Re: 70AARcuda] #161119
12/04/08 03:08 PM
12/04/08 03:08 PM
San Diego
64dartsb Offline
64dartsb  Offline
San Diego
I used to do this all the time in my car, and I've broken a couple of transmissions cause the car just breaks the tires loose and goes sideways it's real fun. I guess that was what was breaking them though. What exactly does it break? and if I don't do that will the car be ok on the street?
sorry no need to hijack but I was just about to post a very similar topic
-matt
if your dreaming of your car then it's your dream car....
Re: Manual Valve Body for a Daily Driver [Re: 70AARcuda] #161120
12/04/08 03:11 PM
12/04/08 03:11 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
The people I have known that have done it have all went back to a standard valve body. It's probably fun at first and then gets irritating over time.
Re: Manual Valve Body for a Daily Driver [Re: Neil] #161121
12/04/08 04:07 PM
12/04/08 04:07 PM
Southern Maryland
klunick Offline
klunick  Offline
Southern Maryland
I have driven my Trans Am with a manual valve body for over 25 years. On a car that is not an everyday driver it is not that big of a deal. I found it to be extremely fun and often folks thought I had a stick. I will have several cars set up this way when I get done but my only suggestion is if you have more than one car setup manually, use the same shifter in all the cars.
67 Barracuda FB 69 Superbee "Southern Maryland: If you want a good looking woman, you had better bring her with you"
Re: Manual Valve Body for a Daily Driver [Re: GTX MATT] #161122
12/04/08 04:19 PM
12/04/08 04:19 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The e-bay offering is the oldest and most basic design reverse manual VB; the main reason they are not recommended for the street is that, with the lack of low-band apply, there is potential for damage when the ill-informed user abuses them. (like in the example 70AARcuda
mentions)
The newer design VB's have low-band apply with a check ball in the rear servo circuit to mitigate harsh downshifts to 1st.
The VB in the link below is the best/safest design available for the street:
https://www.coperacingtrans.com/product_info.php?cPath=23&products_id=67
Re: Manual Valve Body for a Daily Driver [Re: klunick] #161123
12/04/08 04:21 PM
12/04/08 04:21 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
I've had a forward pattern manual valve body in my Charger for several years. It's no trouble at all. I've got a slight 2-3 overlap but once I get that tuned out it will be all good.
Re: Manual Valve Body for a Daily Driver [Re: John_Kunkel] #161124
12/04/08 04:25 PM
12/04/08 04:25 PM
i got the Transaction Cheetah Manual/Automatic forward shift valve body. It works like an automatic shift but will kick down whenever you want. You still need the kick down linkage.
I believe it is a low band apply VB as it engine brakes in first
Re: Manual Valve Body for a Daily Driver [Re: John_Kunkel] #161125
12/04/08 04:27 PM
12/04/08 04:27 PM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
mentions)
HAHA GOOD TO KNOW ABOUT THE COASTING THING. I do this ALL THE TIME with my low band apply 904 and man when I do it the car JUMPS AND GOES. Ive convinced alot of my buddies the car has good power just by accelerating normally until I get the engine up to 3500 or so and coasting until its around 2500-3000, step on it and it kicks HARD and its just a 273. Doesnt keep pulling after 4000 though so I just let back off and go into second driving normally. Lots of people go "HOLY S*** THIS THING PULLS HARD" but its just the deception. I will miss the hum of first gear when I slow down though, it just sounds cool!
Does the manual valve body mean anything different for the sprag? The transmission is a stock 727 out of a '72 340 Demon, is it okay to just put the manual valve body in? The car is going to have maybe 420 ft lbs of torque max and 370 horse, more likely 350 horse and 400 ft lbs sure grip rear end, and not too much tire, probably 225/70/15s.
Will this VB work okay though? Im not looking for max transmission performance, just good performance and some fun. Its a street car I might hit the track this summer once or twice just to see what it does, but its a '67 Satellite and if it runs mid 13s on street tires I will be happy with it for now until I have the funds to go big block. Im working with a budget of about 500 bucks to get the engine backtogether, after my cam, lifters, and valve springs im going to be left with about 250 for the transmission.
Im just trying to get the thing to be daily driver reliable and fun, and I drive it literally every day unless there is snow/salt on the road. Right now the 273s got some carb issues and the 904 works alright but had a leak, the engine leaks from a few spots and looks like crap. I just want to be able to hop in and go and not worry about the carb hanging up and flooding etc.
Re: Manual Valve Body for a Daily Driver [Re: GTX MATT] #161126
12/04/08 08:46 PM
12/04/08 08:46 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
i have a turbo action cheetah reverse manual in both of my drivers. love them. acually makes a car easier to drive on icy streets as you can take off in 2nd and leave it there, and not have to worry about an upshift breaking the tires loose. as mentioned above, do NOT floor it when you are coasting in low. NO getting in and out of the throttle in low. you could damage the sprag,which could explode the front drum,which will destroy your transmission,damage your car and maybe damage you.
Re: Manual Valve Body for a Daily Driver [Re: forphorty] #161127
12/04/08 08:59 PM
12/04/08 08:59 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I thought that's what the cheeta pro street forward pattern mvb's were supposed to prevent. They specifically say those ones are safe for street use.
Re: Manual Valve Body for a Daily Driver [Re: DaytonaTurbo] #161128
12/04/08 09:16 PM
12/04/08 09:16 PM
Kentucky, USA
derekeh Offline
derekeh  Offline
Kentucky, USA
Wow i didnt know you shuoldnt play aruond in first gear like that. I had a 727 with a reverse manual valve body and played around with it all the time in 1st. It slipped horribly bad from 2nd to 3rd. The fluid was black when i checked it a couple weeks later lol. Just curious but I have a stock 904 transmission behind a mild built 318. Will it hurt to not use my kickdown linkage with it and just shift manually all the time?
Re: Manual Valve Body for a Daily Driver [Re: derekeh] #161129
12/04/08 09:25 PM
12/04/08 09:25 PM
Manitoba, Canada
Manitoba, Canada
Yep, you'll burn up your transmission just as quick. Either leave it auto or install a mvb intended for street use and use it as directed.
Re: Manual Valve Body for a Daily Driver [Re: DaytonaTurbo] #161130
12/04/08 09:28 PM
12/04/08 09:28 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
I run one in my Charger,,,street car,,,and love it,,,,sorta like driving a stick,,,,,and i can shift it when i WANT,,,as opposed the car shifting when it thinks it should,,,,
no issues,,,except as mentioned above,,,have to be careful in first gear,,,,
If the tires go up in smoke in first,,,i usually pull it to second gear,,,instead of getting off and then on it again in first..........
Re: Manual Valve Body for a Daily Driver [Re: DaytonaTurbo] #161131
12/04/08 09:32 PM
12/04/08 09:32 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Kickdown linkage is important. I bought a mustang project car that had a rebuilt 302 and a C4 with a couple hundred miles on them. The trans was already toasted from being driven without the kickdown hooked up. I ended up getting another C4 core and starting over.
Re: Manual Valve Body for a Daily Driver [Re: forphorty] #161132
12/04/08 09:33 PM
12/04/08 09:33 PM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
So then if I am coasting in low and I want to get on is it ok if I get the car going under the power of the engine and then floor it?
Re: Manual Valve Body for a Daily Driver [Re: DaytonaTurbo] #161133
12/04/08 09:36 PM
12/04/08 09:36 PM
Kentucky, USA
derekeh Offline
derekeh  Offline
Kentucky, USA
I can buy a 727 i used to own that had a manual valve body in it for $75 or prob less if i can trade some junk to it. The tranny needs rebuilt but could I use the manual valve body in my 904? Even if it will work would it hurt the 904 since its a stock one?
Re: Manual Valve Body for a Daily Driver [Re: GTX MATT] #161134
12/04/08 10:09 PM
12/04/08 10:09 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
As for harsh shifts, my dad and I both run turbo action manual valve bodys with low band apply (called the pro street model) and the shifts are firm but not jarring at all. If you're on the gas, they will definitely screech the tires on the 1-2 shift.
The shifter is what I think would make it more annoying on a daily driver. A stock console shifter is OK, but a ratchet shifter I would not want to be clicking through every day as I do on my dart (weekends only).
Re: Manual Valve Body for a Daily Driver [Re: DaytonaTurbo] #161135
12/04/08 10:12 PM
12/04/08 10:12 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
yes, you are correct. the pro street forward pattern is low band apply. i have the old reverse pattern no band apply. the ebay link gtxmatt provided is also no low band apply valve body.
