ralley wheel silver #1611232
04/23/14 11:56 PM
04/23/14 11:56 PM
oberlin, Ohio
Rapid340 Offline OP
Rapid340  Offline OP
oberlin, Ohio
Does anyone know of a good over-the-counter spray paint that is a decent match for ralley wheel argent silver? I haven't had good luck getting paint out of MP paint cans. Doesnt need to be perfect as these wheels are going on a driver.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: ralley wheel silver [Re: Rapid340] #1611233
04/24/14 01:53 AM
04/24/14 01:53 AM
I'd maybe see what Rustoleum has in a close match which is no ans to your Q. Here's a BTT for ya
Re: ralley wheel silver [Re: RapidRobert] #1611234
04/24/14 02:19 AM
04/24/14 02:19 AM
Ridgeland Wi
mopars_1 Offline
mopars_1  Offline
Ridgeland Wi
krylon dull aluminum
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: ralley wheel silver [Re: mopars_1] #1611235
04/24/14 02:28 AM
04/24/14 02:28 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Can that still be purchased, if so where?
Re: ralley wheel silver [Re: 6bblgt] #1611236
04/24/14 02:55 AM
04/24/14 02:55 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Bought some with a friend online. Use for grille, console, dash... silver paint too.
Dull Aluminum Kylon 1403 https://www.google.com/search?sourceid=n.....0.Oj4JNCDuncU
Was a dead match for an original set of 71 Demon rallye rims checking under the trim ring that not exposed.
Re: ralley wheel silver [Re: Rapid340] #1611237
04/24/14 10:44 AM
04/24/14 10:44 AM
STL
cdstl Offline
cdstl  Offline
STL
I wanted a Rallye for my spare. I blasted a used one from Craig's and shot it with this. Came out great and you can even see the date code numbers clearly.
http://www.oreillyauto.com/site/c/detail...9&ppt=C0171
Moparts thread: https://board.moparts.org/ubbthreads/show...;gonew=1#UNREAD
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: ralley wheel silver [Re: Rapid340] #1611238
04/24/14 01:15 PM
04/24/14 01:15 PM
On the open road
Hrtbkr Offline
Hrtbkr  Offline
On the open road
I always use Krylon 1403 dull aluminum on my wheels. I've been told it's not an exact match but it looks very close to me (I'm not a 100 point type of guy). I haven't seen it in stores recently-but you can get a case of six on-line from lots of places. It's also a close match for zinc plating.
While outside on the turnpike They got this new hit tune Where thrills become as cheap as gas And gas as cheap as thrills
Re: ralley wheel silver [Re: 6bblgt] #1611239
04/24/14 01:23 PM
04/24/14 01:23 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Dan- the ACE hardware stores stock it around here. I have to say, it isn't a perfect match. I just sprayed a set of 390 wheels for my Bee and left the original silver intact, on the inside area between the beads. You can clearly tell the difference. The original silver isn't as flat and the Krylon is a little lighter. But it looks good enough to play the part.
BTW- the center cap paint is too dark... That is the Krylon Medium argent textured stuff. It does look a bit lighter in person, but it is still too dark for sure.
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5
‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7
‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
Re: ralley wheel silver [Re: 70440+6bbl] #1611240
04/24/14 02:30 PM
04/24/14 02:30 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
This is Krylon 1401 bright silver,now 22 yrs old.I have a pair of N.O.S. small bolt rallies and the are almost identical.
Re: ralley wheel silver [Re: 62maxwgn] #1611241
04/24/14 03:54 PM
04/24/14 03:54 PM
near New Haven, CT
fireeng Offline
fireeng  Offline
near New Haven, CT
My local dodge dealer sells a mopar paint in a spray can. I can check when I get home but I believe it even says rallye wheel silver on it.
2016 Diesel Ram 3500 Mason Dump
1971 Challenger
2013 Jeep Wrangler
1979 Dodge Ram Power Wagon 400 Mini Pumper
My other car is a Fire Truck.
Re: ralley wheel silver [Re: 62maxwgn] #1611242
04/24/14 06:55 PM
04/24/14 06:55 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
I'm going to try that shade on my '71 GTX ralleys.
Re: ralley wheel silver [Re: 70440+6bbl] #1611243
04/24/14 08:03 PM
04/24/14 08:03 PM
oberlin, Ohio
Rapid340 Offline OP
Rapid340  Offline OP
oberlin, Ohio
Thanks for all the response.
Anyone try Duplicolor wheel silver HWP101?
Re: ralley wheel silver [Re: Rapid340] #1611244
04/24/14 08:14 PM
04/24/14 08:14 PM
New York
E
EL5 71 Offline
EL5 71  Offline
E
New York
I used this and it looks excellent.
Re: ralley wheel silver [Re: EL5 71] #1611245
04/24/14 08:15 PM
04/24/14 08:15 PM
New York
E
EL5 71 Offline
EL5 71  Offline
E
New York
2
Re: ralley wheel silver [Re: EL5 71] #1611246
04/24/14 08:16 PM
04/24/14 08:16 PM
New York
E
EL5 71 Offline
EL5 71  Offline
E
New York
3
Re: ralley wheel silver [Re: fireeng] #1611247
04/24/14 10:22 PM
04/24/14 10:22 PM
near New Haven, CT
fireeng Offline
fireeng  Offline
near New Haven, CT
Here it is. Looks good on mine.
1971 Challenger
2013 Jeep Wrangler
Re: ralley wheel silver [Re: fireeng] #1611248
04/24/14 10:30 PM
04/24/14 10:30 PM
near New Haven, CT
fireeng Offline
fireeng  Offline
near New Haven, CT
one of the wheel
1971 Challenger
2013 Jeep Wrangler
Re: ralley wheel silver [Re: fireeng] #1611249
05/04/14 10:10 PM
05/04/14 10:10 PM
oberlin, Ohio
Rapid340 Offline OP
Rapid340  Offline OP
oberlin, Ohio
Thanks again to everyone.
I went with the dupli-color caliper paint and all I can say is it is VERY close to the mopar paint, I now have wheels painted with each and I cant really see any difference. Also the duplicolor charcoal wheel paint is a great substitute for 71 center caps if you dont mind the smooth texture and a slight color difference. Sorry for the lighting in this pic.
BTW, with all the work that goes into repainting a set of 45 year old wheels that have multiple coats already, the wheel vintiques rallies start to look more like a bargain (of course the wheel face at least needs a coat of paint that is color correct.
Re: ralley wheel silver [Re: Rapid340] #1611250
05/04/14 10:16 PM
05/04/14 10:16 PM
oberlin, Ohio
Rapid340 Offline OP
Rapid340  Offline OP
oberlin, Ohio
here is the car, just a driver/cruiser.
Re: ralley wheel silver [Re: Rapid340] #1611251
05/05/14 01:30 AM
05/05/14 01:30 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Usually the 44 year old wheels are round though as opposed to the repros made with modern equipment which generally aren't round.
The paint looks good I'll have to go get some.
Sheldon
