Re: ralley wheel silver
[Re: Rapid340]
#1611233
04/24/14 01:53 AM
04/24/14 01:53 AM
RapidRobert
I'd maybe see what Rustoleum has in a close match which is no ans to your Q. Here's a BTT for ya
[Re: mopars_1]
#1611235
04/24/14 02:28 AM
04/24/14 02:28 AM
Posts: 17,516 Las Vegas, NV
6bblgt
Las Vegas, NV
krylon dull aluminum
Can that still be purchased, if so where?
[Re: 6bblgt]
#1611236
04/24/14 02:55 AM
04/24/14 02:55 AM
Posts: 27,467 So Cal
autoxcuda
So Cal
Bought some with a friend online. Use for grille, console, dash... silver paint too.
Dull Aluminum Kylon 1403 https://www.google.com/search?sourceid=n.....0.Oj4JNCDuncU
Was a dead match for an original set of 71 Demon rallye rims checking under the trim ring that not exposed.
[Re: Rapid340]
#1611238
04/24/14 01:15 PM
04/24/14 01:15 PM
Posts: 821 On the open road
Hrtbkr
On the open road
I always use Krylon 1403 dull aluminum on my wheels. I've been told it's not an exact match but it looks very close to me (I'm not a 100 point type of guy). I haven't seen it in stores recently-but you can get a case of six on-line from lots of places. It's also a close match for zinc plating.
While outside on the turnpike
They got this new hit tune
Where thrills become as cheap as gas
And gas as cheap as thrills
[Re: 62maxwgn]
#1611241
04/24/14 03:54 PM
04/24/14 03:54 PM
Posts: 915 near New Haven, CT
fireeng
near New Haven, CT
My local dodge dealer sells a mopar paint in a spray can. I can check when I get home but I believe it even says rallye wheel silver on it.
2016 Diesel Ram 3500 Mason Dump 1971 Challenger 2013 Jeep Wrangler 1979 Dodge Ram Power Wagon 400 Mini Pumper My other car is a Fire Truck.
[Re: 62maxwgn]
#1611242
04/24/14 06:55 PM
04/24/14 06:55 PM
Posts: 5,268 NY
70440+6bbl
NY
This is Krylon 1401 bright silver,now 22 yrs old.I have a pair of N.O.S. small bolt rallies and the are almost identical.
I'm going to try that shade on my '71 GTX ralleys.
[Re: 70440+6bbl]
#1611243
04/24/14 08:03 PM
04/24/14 08:03 PM
Posts: 2,091 oberlin, Ohio
Rapid340
oberlin, Ohio
Thanks for all the response.
Anyone try Duplicolor wheel silver HWP101?
1971 Factory Appearing Duster 340 11.000 @ 122 mph
[Re: fireeng]
#1611249
05/04/14 10:10 PM
05/04/14 10:10 PM
Rapid340
oberlin, Ohio
Thanks again to everyone.
I went with the dupli-color caliper paint and all I can say is it is VERY close to the mopar paint, I now have wheels painted with each and I cant really see any difference. Also the duplicolor charcoal wheel paint is a great substitute for 71 center caps if you dont mind the smooth texture and a slight color difference. Sorry for the lighting in this pic.
BTW, with all the work that goes into repainting a set of 45 year old wheels that have multiple coats already, the wheel vintiques rallies start to look more like a bargain (of course the wheel face at least needs a coat of paint that is color correct.
[Re: Rapid340]
#1611250
05/04/14 10:16 PM
05/04/14 10:16 PM
Rapid340
oberlin, Ohio
here is the car, just a driver/cruiser.
