The old 2005 up Hemi stalls after fill-up problem.... #1611020
04/23/14 02:26 PM
04/23/14 02:26 PM
Logan Twp, NJ SEND BEER!
KAZI Offline OP
No More Duster
KAZI  Offline OP
No More Duster
Been trying to find info for a friend who has the stalling after fill-up problem that has plagued earlier Hemi cars. 2005 300C. The web shows that it was a known tank problem and a limited recall was done on some cars to replace the tank. Some said they took the vacuum line that goes from the intake manifold to the purge solenoid (all under the hood) and insert in line a fuel filter that traps the fuel and then bleeds it slowly. Anyone know of this or any other "fixes" that might work without pulling the tank?
Kazi
Re: The old 2005 up Hemi stalls after fill-up problem.... [Re: KAZI] #1611021
04/24/14 01:32 PM
04/24/14 01:32 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
there is a diagnose only
TSB for the 2005 vehicles that suffer from this
http://www.xkjeeps.com/TSB/tsb_xk_1400109a.pdf
my mother's 2005 3.3 minivan developed this same problem suddenly at about 50,000 miles and 7.25 years, just past the 7 year extended warranty she bought which would have covered the $700 tank replacement.
the suggestion to put a large internal volume fuel filter in the vacuum line to the purge solenoid sounds like it might have potential as a fix.
even better might be a large vacuum reservoir like you see on some commercial trucks
Re: The old 2005 up Hemi stalls after fill-up problem.... [Re: 360view] #1611022
04/24/14 08:45 PM
04/24/14 08:45 PM
Central NY
GarageDodge Offline
GarageDodge  Offline
Central NY
2005-2006 lx cars lifetime warrenty for stalling problem after filling,just announced.
Re: The old 2005 up Hemi stalls after fill-up problem.... [Re: GarageDodge] #1611023
04/25/14 10:53 PM
04/25/14 10:53 PM
aZLiViN
J_BODY Online rolleyes
J_BODY  Online Rolleyes
aZLiViN
tank toppers.... gotta get every drop of gas you can in there. Saturates the charcoal canister and over time damages the system and wah-la! Stalling issue.
Re: The old 2005 up Hemi stalls after fill-up problem.... [Re: 360view] #1611024
04/25/14 11:07 PM
04/25/14 11:07 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
Is this the correct TSB? This one refers to the tank being hard to fill or the nozzle shutting off repeatedly. I believe the OP is referring to the car stalling shortly after tank fill up. Our 05 Caravan does this all the time--about killed me a couple times leaving the gas station...
And no, I don't "squeeze every drop in"...
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: The old 2005 up Hemi stalls after fill-up problem.... [Re: KAZI] #1611025
04/28/14 11:53 AM
04/28/14 11:53 AM
Wichita Kansas
6PacCuda Offline
6PacCuda  Offline
Wichita Kansas
My 05 Magnum R/T does the same thing if you let is go until the pump kicks off. So I usually only fill it 3/4 full which is a pain sometimes. I've read that the 05's have a big problem with the fuel tank. And it's not from trying to get every last drop in them.
Re: The old 2005 up Hemi stalls after fill-up problem.... [Re: KAZI] #1611026
04/28/14 12:37 PM
04/28/14 12:37 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Kazi
FWIW We bought a used 2005 durango with the hemi engine with 50K miles on it. Our problem was it would puke out gas all over the ground when it got full no matter how slow we filled it. It never stalled though.
I called the dealer and they were not aware of a recall on it at first. I called back a couple months later and then they were aware of a recall.
WE took the vehicle in and they replaced the whole gas tank. Wife fills it up and takes it to work. The full tank leaked all over the ground in her work parking lot. Called the dealer and they came and towed it back to the dealer. They said a plastic fitting cracked when they installed the tank. They installed a second new tank it don't leak gas anymore and don't puke it out when it get's full. It doesn't stall either. It didn't cost us any money for the new gas tank.
But now I get a code every once in while that indicate a small Evap leak which I'm pretty sure is on the top of the tank. I just keep clearing the code, sometimes it takes months for it to come back.
What a screwy deal... Now the body is rusting like crazy, not real happy or proud of our 2005 durango.
Did you ask the dealer if there is a recall for the problem? Check this out... web page
