69 M code cuda #1610927
04/23/14 11:06 AM
04/23/14 11:06 AM
OhiO
drgordi Offline OP
drgordi  Offline OP
OhiO
Just looking for some guidance on my cuda. I was wondering if there is a primer or paint out there for the underside of my car it only had undercoating inside the wheel wells and I was curious as to what is best to use to match the stock dip color I assume for the complete underbody I have pictures of the red spray pattern but the grey was completly gone. The only color that I have to go by is a small strip from under the bump stops along the rear frame rails.
Re: 69 M code cuda [Re: drgordi] #1610928
04/23/14 02:29 PM
04/23/14 02:29 PM
USA
big-block-dave Offline
USA
Chris, there is under carriage gray out there but I forget who has it, i'm sure someone else will chime in. My friend has mixed his own grey that looks good. I don't really know if anyone can really tell the difference??
Keep up the work on that red FB, Dave.........PS did u see the large post on here for "1969 Barracuda M code"? Read thru it and follow along to maybe get some good info!
I'm the CARETAKER of Weinstats '69 440 'cuda registry and have 104 of the 360 cars to date. 84 fastbacks/20 coupes. Always looking for new(REAL M-code) '69 440 'cudas to add to the registry so drop me a note if any are found or known. This isn't a publicly released registry. Thanks, Dave
Re: 69 M code cuda [Re: big-block-dave] #1610929
04/23/14 05:30 PM
04/23/14 05:30 PM
OhiO
drgordi Offline OP
drgordi  Offline OP
OhiO
Thanks Dave. This car is to complete not to go back as exact as I can. The other post has a lot of good info as well. The car is starting to take shape. Looking at all the red interior pieces WOW there is a lot more parts to a fastback than e or b cars, no wonder there were extra screws everywhere under the carpet.
Re: 69 M code cuda [Re: drgordi] #1610930
04/23/14 06:13 PM
04/23/14 06:13 PM
MA
steve70 Offline
steve70  Offline
MA
1970 Challenger T/A 4 speed
Re: 69 M code cuda [Re: steve70] #1610931
04/24/14 04:00 AM
04/24/14 04:00 AM
OhiO
drgordi Offline OP
drgordi  Offline OP
OhiO
That will be a good start. Thanks for the info on Ricks
