Carb number for a '66 R/T? #1610749
04/22/14 09:28 PM
04/22/14 09:28 PM
The Grand State of Confusion-O...
SKR8PN Offline OP
SKR8PN  Offline OP
Customer has a 66 Coronet R/T with a 440. Has a race AFB on it now that doesn't even come close to fitting properly and works even worse.
He wants to find a rebuildable carb that will fit as far as kickdown linkage and throttle cable.
What am I looking for? Carb number?
Karma has no menu. You get served what you deserve.
Re: Carb number for a '66 R/T? [Re: SKR8PN] #1610750
04/22/14 10:00 PM
04/22/14 10:00 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
No such thing. RT started in 67. If a 67 you'll need to know which trans and if California or not.
Re: Carb number for a '66 R/T? [Re: ScottSmith_Harms] #1610751
04/22/14 10:30 PM
04/22/14 10:30 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Not sure if he is looking for originality, or functionality. Even if it is an automatic, You could run the 4326 or 4327. I would skip the Calif. carbs personally. But honestly, I don't think there is anything fundamentally different about a 66 that would require something different than any 440 factory or aftermarket replacement square bore carb.
Re: Carb number for a '66 R/T? [Re: BSB67] #1610752
04/22/14 10:41 PM
04/22/14 10:41 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Again, if you want the correct number you'll need to figure out exactly what he has.
There's nothing at all wrong with the CA carbs. As far as what will fit and look stock, here you go;
Ebay 67 440 Carb
Re: Carb number for a '66 R/T? [Re: ScottSmith_Harms] #1610753
04/22/14 11:06 PM
04/22/14 11:06 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Ebay 67 440 Carb
Right. If that is what he is asking.
Re: Carb number for a '66 R/T? [Re: BSB67] #1610754
04/23/14 05:39 PM
04/23/14 05:39 PM
SKR8PN Offline OP
SKR8PN  Offline OP
Just found out it IS a 67.
Customer doesn't care about originality so much, just needs one that works.
Thanks guys.
Re: Carb number for a '66 R/T? [Re: SKR8PN] #1610755
04/24/14 09:50 AM
04/24/14 09:50 AM
Lakeland FL
floridian Offline
floridian  Offline
Lakeland FL
Tell him to buy a new Edelbrock and buy the kickdown attachment..
Re: Carb number for a '66 R/T? [Re: floridian] #1610756
04/25/14 11:35 AM
04/25/14 11:35 AM
SKR8PN Offline OP
SKR8PN  Offline OP
Mind showing me a link to the kickdown kit? I have yet to be able to locate one....
Re: Carb number for a '66 R/T? [Re: SKR8PN] #1610757
04/25/14 12:08 PM
04/25/14 12:08 PM
edelbrock Mopar throttle adapter #1481. $9.97 at Summitt. There's an AFB #4131S for $100 in the for sale section here which iirc is correct for a 66 HP 440. I have 2 of em (4131S) on a dual quad "B" single plane '58 iron intake going on a 451
Re: Carb number for a '66 R/T? [Re: BSB67] #1610758
04/25/14 12:34 PM
04/25/14 12:34 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Technically speaking there was no "HP" 440 in 1966, just the "TNT" 440 for the Chrysler 300's etc. 1966's were a very different engine as compared to a 67 HP, smaller port heads, low rise intake, log style exhaust manifolds, etc. made the first year 440 basically nothing more than a bored out 413. The 4131 carb was the same one used on many of the mundane small valve head/LP 1966 383/413/440 engines, there was nothing "HP" about them in the least.
So, while the 4131 carb will work fine, a correct 67 carb (both being in stock form) will be a better unit more suited for a true 67 HP engine. An Edelbrock will also work fine but be sure to do a price check before just ordering a new carb, used originals rebuilt/restored are usually competitively priced and will always be worth more later if you decide to sell.
Re: Carb number for a '66 R/T? [Re: ScottSmith_Harms] #1610759
04/25/14 12:53 PM
04/25/14 12:53 PM
Alright, Yeah I goggled it for some more info & it came back with '66 383/325 and dodge 440/350 and plymouth 440/365 but moot points I guess since his is a 67. Not sure how my dual quad 4131 setup will work/turn out but it sure looks good
